Newton’s Gravity Defying Puzzle - 3D Print
16,623
72
15
Posted
Introduction: Newton’s Gravity Defying Puzzle - 3D Print
This puzzle was dropped off on my desk last week. The "rocket" is placed in the cup. You must remove it without dumping it out or using tools (paper clips, tape, etc.). The problem is that there is no place to grab the rocket. How do you get it out? See video at the end if you can't figure it out.
I usually make projects from wood but I don't have a lathe. Therefore, I opted for a 3D print with dimensions taken from the wood version. The CAD files are included in the last step.
Step 1: Wood Version
I took the dimensions off the actual parts to create the CAD files. The wood version can be purchase here.
Step 2: Part Drawings
I included drawings in case someone wants to make the parts out of wood.
Step 3: 3D Print
The white/magenta version is printed. Both versions worked the same.
Step 4: CAD Images
Have you mentally figured it out yet?
Step 5: Video Solution
Step 6: CAD and STL Files
I included STEP along with the STL files in case you want to modify the dimensions.
Enjoy your rocket!
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
16 Comments
Press the tip of your finger on the top and lift the rocket out that way
Easier said than done :)
Piece of maple and a piece of mahogany 45 minutes at the wood lathe, thanks
I figured someone with a lathe would make it. Have you tried it out on anybody yet?
My first guess before seeing the "solutions" (which kinda violate the no tools rule) was to use your mouth to blow it out OR (assuming its clean) just get some suction going with your lips and kinda suck it out.
Nice little object. But isn't an air compressor technically a tool? The vendor of this device just blows on it with his mouth.
Great Minds - Newton Solution - YouTube : https://www.youtube.com/watch?v=niZ46SaYKww
This demonstrates Bernoulli's principle, so I don't see where the 'Newton' comes in.
Airhose would be Bernoulli puzzle.
I actually thought about both those options to remove the "rocket". Interesting though.
I've tried it on about 25 people. Only 2 people initially went to the blowing route. Most people asked a lot of questions like:
Can I dump it out? No
Must it stay on a flat surface? Yes
Can I spin it? Yes as long as the bottom doesn't leave the table
Can I use paper, tape, tools, etc? No
Can I bang on the table from below? Yes, but assume the table is heavy
Can I suck it out? Maybe, but that would be nasty after 10 other people tried it.
One person actually shoved his thumb on the top of the cone for 30 seconds and pulled it up real quick. He was able to get it out with this method.
The fastest way is definitely to blow on it. Sorry for using an air compressor in the video. It was readily available.
