Introduction: Nexus 10 Stand... of DOOM!
Use your otherwise toss able packing.
Tape and glue free!
Step 1: Your Nexus 10 Box
This is it.
Look at it.
Revel in it.
This is your box, there are many like it, but this one is yours.
Step 2: Open It...
...as one does with boxes fairly often.
Unless you happened to be named Pandora.
Then don't ever open your box.
EVER.
BAD THINGS HAPPEN.
Step 3: The Base
It are belong to you.
We'll be using the lid of the box as our base, as everything else will fit IN the box.
Step 4: Accessories Box Insert
Take it out.
Because I said so.
Or not... you rebel, you.
Step 5: Box-ception
You now have an open box inside an open box.
Good for you.
Step 6: Insert
Place the insert from the little box, perpendicular to and inside the lid.
This will act as a spacer for the other half of the box to prevent it from sliding too far forward and falling into the lid.
Step 7: Remove Insert
No, not the one we just put inside the lid, that would be counter-productive.
Take the OTHER insert out of the main box.
Put it aside, we won't be needing it.
It has no purpose here.
Use it for another project.
Or burn it.
Step 8: Oh, and Those Too
Remove the two secondary "wall" inserts in the box.
We don't need those either.
Step 9: Flip It. Stick It.
Place the other box half inside the base as it would be inside the lid, if the box were upside down of course.
The lip closest to you (of the flipped box) should sit inside the insert's front gap.
The insert should prevent the box from sliding all the way forward.
Step 10: Little Help From a Little Friend
Inside the little box is an insert that the wall charger was originally in.
Squish it flat.
Step 11: Last Bit
Place the squished insert up against the inside closet wall of the lid.
It will stick up from the base and this will act as the catch from the bottom edge of your tablet.
Step 12: Congratulations!
You now have an elegant, up-cycled stand that preserves the quality of the box while making your tablet more desk- and lap-friendly.
Epilog Challenge V
Instructables Green Design Contest
