3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
NiCrome "hotwire" ignition for propane flame effects
NiCrome \"hotwire\" ignition for propane flame effects
I'm going to give a run-down of the nicrome ignition system (aka Juniper) that we used on 2PiR this year.
2PiR uses high velocity, high speed, computer sequenced effects. Because of these traits, it is poorly suited for more conventional pilot flames, such as the low pressure stainless steel wool style or the bernzomatic torch type. If you are making a flame effect for anything that is not high-repetition, high velocity, and terrible on pilots, please consider a different style of pilot than hotwires.
Reasons for using NiCrome:
-Can be extremely reliable
- Won't blow out: good for use in areas you can't access easily
- Can ignite extremely short bursts somewhat more reliably than "orange flame" pilots (this is a debatable point, keep in mind that we started using NiCr wires as a last resort)
- It can look really cool if done well
Reasons to not use NiCrome:
-You need between 9 and 12 amps to get it to autoignition temperature (for propane), at 120 volts, that is a whole bunch of watts. This style is not recommended for generator use.
- You will need to either get a power supply that is 12v x (effects * 15) amps if you are running the ignitors in parallel. If you run them in Series, you can run a bunch (we got 16) on one circuit, but you have the Christmas Lights problem if anything goes wrong.
- They need to be protected very well from shorting to the chassis or shocking bystanders (more on this later)
- It's way overkill for most effects
- The wires look like the inside of a toaster, and that's uncool.
Step 1Me talking you out of using NiCrome
So if you are reading this, you have probably built a flame effect or two. If you really haven't gotten deep into ignition woes, just quit reading here and don't worry about stuff like this. Normal, dumb, steel wool and 1/2 psi propane will work amazingly well for making a yellow flame that will light just about anything.
If you are doing something for an art car or whatever, just know that from here until the finished project was (for us) around 80 man hours, 4 priority shipments from McMaster, and a whole lot of wasted money. Your mileage may vary, but using a system like this will be amazingly expensive and time consuming compared to more conventional pilots.
32 comments
Nov 30, 2009. 2:45 AMgadlen says:
 That is just fantastic! Thanks for sharing your experience and writing this up! You'd think it would be easier to make fire, eh?   2 pi r rox!
Jul 21, 2009. 8:03 PMBigev says:
Great Trogdor reference there.
May 14, 2009. 8:52 AMDrStoooopid says:
I see that you've got the tanks on their side. You do realize that this could cause a potential problem, because liquid can cause a backflash. Also, propane is heavier than air, which means any escaping vapor, or leaks will hang at ground level, so if you have a stray spark, you've got yourself a problem.
May 14, 2009. 10:15 AMDrStoooopid says:
That's good to hear....carry on.
Jun 5, 2008. 8:09 PMBuildAnything says:
I need help igniting propane for a a stunt limo I built. I added a propane tube to the side of the limo to make it appear on fire. Can you help?
Aug 1, 2007. 2:56 PMTetranitrate says:
Some more footage from the fire arts festival:
Great project, I'm looking forward to more.
Dec 27, 2007. 9:31 PMichipoodle says:
Yeah!!!!!!!!!!!!!!!!!! FFFFFFFIIIIIIIIIIIIIIIIIIIIIYYYYYYYYYYYYYYAAAAAAAAAAAHHHHHHH!!!!!!!!!!!!!!!!!!!! Tetranitrate, you need to ship me everything pyro related! All hail the fire king! Lol, this instructable is cool though...
Aug 2, 2007. 3:52 AMll.13 says:
Wow, totally awesome! but why Ayumi Hamasaki ??
Aug 1, 2007. 4:12 PMcrapflinger says:
....is the guy in the fire suit playing DDR?...that's hilarious!!
Aug 1, 2007. 4:26 PMTetranitrate says:
Dance Dance Immolation. You can see the sign for it in the third picture on the intro step.
Aug 2, 2007. 1:12 PMTetranitrate says:
Oh cool, I didn't know you guys had done both of them. You should post a DDI instructable.
Aug 1, 2007. 2:58 PM!Andrew_Modder! says:
where do you get NiCrome? other than online? (home depot, etc?)
Aug 1, 2007. 3:45 PMBen Dejo says:
A toaster is a good source of NiCrome wire.
Aug 26, 2007. 7:45 PMthat one guy says:
I disagree, unitednuclear.com has nicrome, which I used to make near 100 igniters for $3 (total, not each) I even made an instructable on my igniters, although Iv'e already come up with a cooler version (Instructable to come).
http://www.instructables.com/id/E5XKVTSF5R8MR8Y/
Aug 1, 2007. 4:25 PM!Andrew_Modder! says:
where in the toaster? lol? or any other places to get it?
Aug 1, 2007. 5:08 PMallanf0 says:
I imagine the heating elements of toasters and all sorts of other things would be made from NiCrome
Aug 1, 2007. 9:12 PM!Andrew_Modder! says:
damn. someones goda send me there old toaster :-P any offers? ahh? ahh? i pay (little bit)
Aug 12, 2007. 7:01 PMkillerjackalope says:
something you should know is that nicrome wire is very easily replaced by small gauge constantan (another resistant wire) I recognixed this when my dad and i revived a pre-piezo ignition gas lighter that was run on a 2 solution chemical battery unfortunatley the nicrome wire was long turned to dust and i remember the resistance experiments in physic went into school got out some constantan and a bunsen followed by a transformer with croc clip terminals at 12V the wire itself could burst into flame so I made a small coil to lower the heat and found the perfect ignition coil for the lighter and the bunsen but basically using the right length of wire is all it comes down to as long as it resists creating heat
Aug 1, 2007. 5:16 PMwestfw says:
Is there an instructable yet on propane flame projectors in general?
Aug 2, 2007. 3:34 AMcomputer_gui says:
Couldn't you just put a large disclaimer? I would be very interested to know how everything worked out, not because i have the time or money to create such a thing but just because it would be interesting to know how such a thing would work.
Aug 3, 2007. 12:09 AMtrebuchet03 says:
Everyone SHOULD know the fire codes when they do something like this, but people who rush build s*** in their garages poison the well for everyone, including me.
That seems like a great instructable in itself -- just on safety and ratings. It seems, that if the well is already poisoned, people will continue to attempt garage stunts - weather you inform them or not.
Aug 2, 2007. 11:09 AMedrabbit says:
nice write up! These things are great when they work, a pain when we melt through them. hehe
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:seraphus
Just your average robotics and fire arts tinkerer.
