Night Light From Used Air Filter
1,854
47
Published
Introduction: Night Light From Used Air Filter
About: Enjoy electronics, mechanics. Fixing appliances and making how to's.
This tutorial will show how to make a night lights from a used air filter out of a generator and a couple of other parts. It can be done within a day and will run off of a wall adapter (12-15v) and will use car brake lights. This light is ideal for camping because it can run off of a car battery and since it is an old school incandescent light it has a warm and natural vibe to it.
Step 1: Parts
Used air filter
DC jack
12 volt adapter@2amps
Car brake lights and sockets
Wire
Heat shrink tubing
Solder
Epoxy
Silicon
Step 2: Tools
Paint brush
Drill and bits
Hammer
Screwdrivers
Soldering iron
Step 3: Burning and Cleaning the Air Filter
Soak the air filter in a flammable liquid or gel and light it up, to protect the grass or ground put it in a oil dish. Once all the paper and glue has been burnt away open up the air filter and break any excess glue away with a screw driver and hammer. After that get some wire wool and clean it up.
Step 4: Wiring
The wiring is very easy the ,two positive's join together onto the DC jack and the whole case is negative. Epoxy the DC jack to the side, after that use some heat shrink tubing to neaten up the wiring.
Step 5: Painting
Take the light sockets off, clean the top and bottom plate and paint it to the color of your choice.
Step 6: Final Product
Get your silicon and glue th pieces together once all the parts are in. This light gets pretty warm and requires a big adapter to run it, it was a cheap,quick,and simple build. The lamp can also be used for camping(it can run off a battery, and charged off solar).
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    2 Discussions
    Very ingenious. There are a number of light options that could be used to exploit all them holes like led strips under the 'lid.'
    Great idea ! And an excellent way to recycle used air cleaners. Love it.
