iImage Information
I had a beat up night stand that I wasn't using. It would just sit there and collect dust. With a little bit of work and some new paint I turned it into a night stand that is also a lamp and a charging station for my portable devices!
Step 1Route the Top of the Night Stand
iImage Information
I used my router to create a groove that went in a rectangle on the top of the table. I use the guide on my router to make sure that the groove was the same distance from the edge all around the table.
Not yet sure if I'm gonna go the, make an induction circuit route or the gut a Powermat and glue it under the table, route.
A table that changes color/brightness when all items are fully charged.
Bright ideas, anybody?
1) Instead of charging cables, since most things are USB now, just install a cheap powered USB hub on the side under the lip of the cutout. That clears up the clutter, as there is only on transformer, and allows you to have a large number of devices charging.
2) instead of cables, you could connect USB to miniUSB adaptors and secure them to the edge of the lip of the cutout, such that the MiniUSB jack protrudes just a bit beyond the edge. Alternately, make the lip float above the top of the plastic, so that the device to be charged can fit underneath, and mount the jack flush. To charge a device, just slide it onto the connector.
3) In addition to the above, or in place of, install retractable USB cables that sit under the lip. That way they are out of sight when not in use and won't be as easily lost.
Nice work!!
(I win, three words!!)
But seriously though.
That is fantastic! Looks very slick and streamlined. I think you have inspired me to build my own "charging station". These seem to be the new "in" thing.
If I do get around to it I'll definatley post pics.
Keep up the good work and congrats on thFeature.
Well, that's not quite accurate. If the receivers were packed in too tightly the ones in close proximity to the transmitter might form a Faraday cage and block the signal. :)
Actually I did something similar but only using a Ikea box
here's the instructable
Your's is much more refined. Well, nicely done ;)
