3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Night vison eyedrops!
Night vision eyedrops a fantesy? Not any more! But, PLESE READ THE FOLLOWING: Do NOT put this in you'r eye, this instructable is bacicly a documentry! Putting unknown things in your eye in NOT SAFE! But we (there is a science fair coming up so my friends and I have a team) DID test it and it worked! (there needed to be more clorphill in the ratio) So it wasent a very powerful inhansment but oh well it works! Once I told my mom she told us NOT to test it anymore...
If you are stuped enough to actually put it in you'r eye then DON'T BLAME ME!!!!
P.s, I got the awared for "Unlimeted Capabilities" so yay for me!
Step 1Matirials
Matirials
You will need:
Pine nettles
Butter knife
Some sort of water container (cups)
Test tube with cork (Or a cup with plastic wrap rubberbanded on top of it)
(OPTIONAL):
Magnifind glass
Tweesers
Funnel
54 comments
1-40 of 54next »
May 28, 2012. 4:32 PMjduffy54 says:
A) I doubt it, unless these just dialate your pupils. The easy way to do this is to close one eye, or use an eyepatch, for about 15 minutes, then go into the dark. Your spelling could REALLY use some help too. Enter the whole thing into microsoft word, use spellcheck, and then copy and past into instructables.
May 5, 2012. 7:59 AM3rd realm creations says:
could you use any green plant or pine needles that are not green?
is  this were you got your info?
May 5, 2012. 5:59 AM3rd realm creations says:
could you use grass or other plants what about the pine needles when they aren't green?
did you use this info
Jan 11, 2012. 11:56 AMsokamiwohali says:
SOOOO...is there any STERILE way to harvest chlorophyl and make these eye drops? if so, how would one go about doing it?
Apr 17, 2011. 1:58 PMmike876763 says:
So if we don't have contacts can we put it in our eye?
Apr 20, 2011. 3:19 PMmike876763 says:
Also wouldn't it be healthier using spring-water instead of tap?
Apr 21, 2011. 5:43 PMmike876763 says:
Can i buy eyedrops and put the cloriphyll in it?
Apr 20, 2011. 4:19 PMArc Trooper 5555 says:
Instead of water straight from the tap, boil the water before use. It will kill all the bacteria and make it safe to use. (That's the water they use for real eye drops.)
Nov 11, 2010. 7:13 PMshabaki says:
im assuming this acts in the same way the drops the eye doctor uses in the way that it dilates your puils therefore allowing more ambient light to enter your eyes making it easier to see in the dark ( eye doctors use it becuase it dilates your pupils large enough they can look into the back of your eye with their instraments) however, it dilate your pupils...alot.....so one might mistake you of using drugs which also dilate the pupils...alot.............that and TRSUT me it STILL makes things that are ALREADY bright ALOT brighter.............aka dont stare at the sun
Nov 12, 2010. 9:30 AMlofty says:
If it was to absorb red light then it would actually reduce the total intensity of the light entering the eye.
How is it (you think) the information is transmitted to the brain?
Nov 13, 2010. 10:32 AMlofty says:
In another comment you said that your friend said he saw "everything is rather whitish"
So is it red or white?
Invisible red light?
Red light isn't invisible.
What wavelengths of light does this affect and what wavelength is this "invisible red light" ?
You still haven't answered my previous question of how the information is transmitted to the brain.
What chemical reactions are happening ?
Jan 23, 2011. 2:18 PMshabaki says:
just reread this convo and i tthink you are refering to infrared light, which :
-is not in the visible range of humans
- isnt "everywhere" but is MOST of "everywhere"
Nov 11, 2010. 8:49 PMkelseymh says:
No, I'm afraid not. Adding pigments to the outside of your eye doesn't make any difference to the live light-collecting cells that are inside your eye (the retina).
Jan 19, 2011. 5:27 PMyoshi1 says:
If you kept it in your bottle or something see through and looked through it at night would it work?
Jan 19, 2011. 8:11 PMyoshi1 says:
Thanks, cool instructable.
For some reason i can't subscribe?!
Jan 20, 2011. 10:54 PMyoshi1 says:
yeah i have now i don't know what i did before.
Jan 6, 2011. 4:06 PMNATIVEBOY says:
well how safe is it with no contacts?
Nov 15, 2010. 6:40 AMBytePilot says:
Alas the poor reporting of scientific discoveries has oncemore bitten us on the collective behind.
PopScott3 is just doing as the articles suggest.
http://discovermagazine.com/2009/sep/04-forget-goggles-chlorophyll-eye-drops-give-night-vision
It's "Science" jim, but not as we know it, ie they've made up a great sounding headline to go with a discovery that's rather different.
Nov 11, 2010. 10:12 PMGhost Wolf says:
Have at all tried to put it in a pair of glasses?
Nov 11, 2010. 10:15 PMGhost Wolf says:
like fill that stuff between the lenses?
Nov 12, 2010. 3:33 AMVadimS says:
Pine needle are vary acidic so this would probably be painful, not strong enough to cause damage so feel free to try. This depends on the amount of water you add.
The mane reason humans can't see as well in the dark as other animals is because we have a lot of cone cells, they allow us to see color but don't work in low light.
The human eye can dilate vary quickly so drops to do that won't make any real difference. Doctors use it to keep them open so they can have a look.
Rod cells take a while to adjust to low light.
Nov 12, 2010. 4:42 AMPKM says:
As far as extracting chlorophyll goes, this looks ok, but I don't think it's going to help you see in the dark.
Saying "it has to be injected into the eye but we didn't want to make it permanent so used eye drops" is like saying "I didn't want to implant this pacemaker permanently so I duct taped it to my chest" or "I didn't want to take my vitamins so I rubbed them into my skin".
It sounds like the fish have chlorophyll in their retinas, where it could conceivably absorb light and transmit it to the brain, but putting it on the outside of your eyes won't work that way.
Nov 11, 2010. 5:26 PMRevolt Lab says:
I can't get myself to believe you are for real. This seems impossible and blinding. If you put together a presentation for the science fair you should post it on this instructable. I would be very much interested in looking at it.
It's certainly not real. It may or may not be dangerous (as I don't know what physiological effect chlorophyll has on the eye).
Nov 12, 2010. 7:38 AMkelseymh says:
Whether "your friend" actually saw better in the dark or not isn't entirely relevant, and a plausible reason has already been addressed (forced dilation of the pupil, as is used during certain kinds of opthamological testing). Your claim that chlorophyll can affect retinal activity is utter nonsense.
1-40 of 54next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:popscott3
I absolutly love airplanes and just about anything with an airfoil. I own 6 Chickens and love inventing and building stuff.
