Introduction: Nightlight Led Laptop 1.2 Version.
Picture of Nightlight Led Laptop 1.2 Version.
 This instructable is basically an improvement in my previous draft,
This fact was caused by two reasons.The first reason is that I had to revise the values of resistance led relief to lower slightly the current feed as LEDs, one by one I have left.
The second reason I was given from a reader of this instructable that he accomplished something similar to my project, I went, and using 7 led instead of 4 as I did myself, and at the same time posing as a current power led 10ma to preserve them by rapid deterioration.
The author of this was SharpyWarpy.
Step 1: Therefore...
Picture of Therefore...
So ... all phases that relate to the construction of support remain the same as the previous version; the enlightening body, instead of using 4 LEDs in parallel, each with its resistance relief, I used 7 LEDs in parallel, each with its resistance in this case that relief was worth 120 ohm to allow a flow of current to each led approximately 10ma totaling 70ma Unlike before where the total power consumption was about 80-90 ma.
Step 2: The Color
Picture of The Color
I changed the colour: Matt Black from the previous version are passed to a silver ... "anodised aluminium". For the rest everything is unchanged, and then I refer you to the first version for any insights.
Step 3: Thanks
Picture of Thanks
A special thanks to SharpyWarpy for having inspired in editing!!!!
Thank you all for your attention, I remain at your disposal for suggestions and/or clarification.
SharpyWarpy (author)2011-03-12
Extremely nice improvements. The keyboard is more evenly lit and the LEDs will last much longer tuned down to 10ma. I like your choice of material for the framework. Aluminium should last a lifetime. Congratulations on a job well done. Keep the great ideas coming, I like your work.
torx (author)SharpyWarpy2011-03-13
Thanks for the compliment and thanks again for your cooperation.
About This Instructable
2,611views
13favorites
License:
More by torx:Horticultural solar panel Simple cutting board from pieces of scrap.Secure Suction Chamber for Disc Sander
Add instructable to:
