loading
Step 3: Remove 8 screws holding lens mount in place
There are 8 screws to remove.  3 larger screws can be seen in the first photo.  There are 5 smaller screws that face into the axis of the lens,  remove all 8, keeping track of where they came from.
Nice tutorial. Out of curiosity I'm wondering if I can use the boyonet mount from one lens to another. One of my AIS lens mount for 105mm lens mount is screwed up and wondering if I can replace that mount using an eBay as is 50mm AIS lens. Is the mount different for different focal length?
<p>I did it!! Thank you for the tutorial! I have the Nikon AF-S Nikkor 18-105mm 1:3.5-5.6G ED lens, and bought a plastic replacement ring of eBay or something for &euro;2,- or so. Half way the repair the lens came apart further than I indented, but fortunately that was fixed by unplugging the ribbon cable from the Auto/Manual focus switch and unscrewing it, fitting the plastic ring again, and plugging/screwing the button back. In short some freighting moments, but I got it in the end :D. <br><br>A tip for people who are going to attempt this: keep the lensparts (zoom ring, focus ring, etc) tightly together, don't pull any up.</p>
<p>almost made it, almost. Pretty sure that I accidentally broke the wire or something, and the body couldn't recognize the lens. Thanks anyway.</p>
<p>hi, thank you for your useful instructions. I was doing the replacement but unfortunately as the cable was so fragile, it broke and <em>I don't jnow what to do with all of it as it is detached. the other problem is that a little piece that took the metal parts in place is broken as well. </em> I am so dissapointed </p>
<p>Do you know if they make metal replacement mounts? I dropped mine last week and while it still functions, I worry about light bleed. </p><p>I was on a cruise and swapped to my 70-300 lens,but it left me using my iPhone for candid photos. That lens has a metal mount and seems so much sturdier.</p>
<p>Thanks so much for this! I just replaced the mount on my 18-55 for my good ol' Nikon D5000. I ended up getting a cheaper part on amazon but it doesn't come as complete as yours from Nikon did. I had to remove the spring loaded inner ring and attach it to my mount before reassembling. Regardless, I made it through and we're back to shooting, just before vacation! Cheers!</p>
<p>I have a Nikon J1 camera and I cant find any replacement parts for a 10-30 mm bayonet mount lens ring. Is there another one that is comparable ? I always see replacement rings for 18-105, 18-135 but never for 10-30.</p>
<p><a href="http://www.amazon.com/Nikon-18-105-18-135-55-200-BAYONET/dp/B00C6OXZ9Q/ref=pd_sim_421_1?ie=UTF8&refRID=1KTT997MW9YHA2950ES6" rel="nofollow">http://www.amazon.com/Nikon-18-105-18-135-55-200-B...</a></p><p>Here is the Amazon link. Nikon doesn't sell the part, they say you have to fix with through and authorized dealer.</p>
<p>Hi </p><p>Gave this a try, broke the connection (white wire). Do I need to get this soldered (I've never done any soldering, but might have a friend who could do it). </p>
<p>I was replacing the mount last night and everything was going great until...I took it the top off again just to make sure it was done right and I also ripped the wire....did you end up soldering it?</p>
<p>Thanks for the detailed instructable. I've performed this repair four times so far on 18-55mm, 55-200mm and 18-105mm Nikon DX lenses, including VRs. Of course the one I've managed to snap the white wire on is the 18-105mm! Have three more lenses awaiting repair that I've picked up for very little and will resell after repair. I get the new mounts on Amazon for ~$8.00. All these headaches so Nikon can save a few dollars by installing plastic mounts rather than metal.</p>
<p>Thank you for the useful guide - I was ultimately successful fixing my D7000 lens thanks to your detailed instructions. I would also point out that the wire connection is quite fragile and will break if stressed too many times - this can be fixed with some solder but it's best to avoid that situation in the first place. Nikon did not have the part is stock, so I ultimately ordered a replacement through ebay. Thanks again!</p>
I just dropped my D7000 and broke the lens mount :( <br>Where did you guys buy a new lens mount? I am looking all over the internet but I cant find anything... I need help please!
<p>Just happened to my D7000's kit lens (18-105), and i can't find a mount replacement on nikon's website. Did you find it anywhere?</p>
I used the Nikon web site - the US number is: 1-800-NIKON-US (1-800-645-6687)
<p>Can't find it on the website in the lenses parts department... will give them a call and see what they can do.</p><p>Thanks :)</p>
is there any ebay seller who actually sell this? i cant find it
Much appreciated pal, got my 18-55 back on the road in 15 minutes with this guide. One tip for fiddly projects like this, I use a thin strip of blu-tack on the desk to put screws into in the order they come out and keep them from rolling away. Also, for putting tiny screws back in place, if the screwdriver is not magnetic, a tiny dot of blu-tack on the end of the screwdriver attaches the screw so you can get it in the relevant hole easily, tighten it and the blu-tack squashes under the pressure and then just scrapes off afterwards. If it helps anyone, I'll be glad!
Awesome information and instructions! A friend pointed me to this site after I broke my Nikon lens mount in a fall. The new mount cost me $12.29 including shipping. The Nikon parts guy couldn't have been more helpful. With the instructions detailed here, I was able to fairly quickly replace the mount. I didn't lose even one tiny screw because of the precautions I took at your suggestion. This task would not have been so easy without this help. WELL DONE!! I only wish Nikon would offer a metal mount replacement, but at least I know I can replace it if it breaks again. Thank you very much!
Just literally broke the lens mount and googled straight away to find out options. This came up in a search. Thanks very much for spending the time putting this together, it's saved me a lot of time. I'm in the middle of contacting Nikon UK for the spare part, hopefully they will have them in stock.
Just an update. Got a response from Nikon. They have the part in stock. I have a 55-200mm lens and the part number for the plastic mount i'm being told is JAA79351-F (Bayonet Mount). It costs &pound;9.81 + postage (&pound;2.00) + VAT. They are quoting a turnaround time of 2-5 days. Hope this helps somebody else.
Last update, got the part from Nikon. Turns out that for the 55-200mm it has a different brass bracket for the cable which attaches to the mount than the 18-55mm however the mount itself is exactly the same. Also the aperture ring and zoom limiter that came with the spare part was shorter than the one already present within the 55-200mm lens, so I just re-used the one inside the lens instead of the new one (which seems like it should belong on the 18-55mm lens. Sadly though, even though the bracket has been fixed, the auto focus motor seems to be broken :-( bad times
Thank you for this! The instructions were easy to understand and you saved me a bunch of money not having to buy a whole new lens.
is there a way that anyone can link me to repair kit on nikonusa.com because i have searched for the kit around the site and i cannot find it anywhere!!! Thanks :)
I called parts at 310-414-8107 i did not see a link for the part on their web site.
thanks!!
Awesome! I actually have a 18-55mm that I got with my D40x and like yourself, broke the lens mount when I dropped it. I didn't know you could buy another lens mount kit. You saved me buying another lens, thanks!
You're a life-saver! I just dropped my camera w/ the 55-200mm attached and popped off all three of those dang little pieces of plastic and was driving home freaking out about how much it was going to set me back when I don't want to replace this lens as I'm saving for a tamron 70-200mm 2.8. but $17 I can do... Thank you!!
&nbsp;Very nice instructable; clear and detailed. I could have used this a few years ago when I broke the mount on a cheap 70&ndash;240 mm. These days, I try to keep to lenses with metal mounts.
My wife just ordered a D5000 kit, I'm sure this will come in handy eventually.&nbsp; Favorited.<br />
About This Instructable
70,994views
22favorites
License:
More by ralbright:Nikon lens mount repair
Add instructable to:
