Ninja Mouse: the Silent Click
Introduction: Ninja Mouse: the Silent Click
Instead of trashing that obnoxiously loud mouse to get a new one, save some money and the environment by modding it into a Ninja Mouse. All you need in a thin knife and whichever type of screwdriver to open it.
NOTE: This mod can takes only a few minutes if you know what to look for. I think it goes without saying, but mod at your own risk.
Step 1: First, Some Numbers
Using an Android decibel meter, I got the following data:
-Ambient Noise 48 dB
-Ninja Mouse 52 dB
-Regular Mouse 74 dB
(The regular mouse is just as loud as my Ninja Mouse used to be.)
If you know about logarithmic scales, you can see Ninja mouse is over 10 times quieter than the regular mouse!
Step 2: Open It Up
There are a lot of different types of mice out there and most all employ means of hiding their screws. Check under the plastic pads and in the battery compartments if you're having trouble finding them.
When you get inside, locate the mouse switches. You should see some rectangular boxes like in picture 3. If you have the square switches like in picture 4, you're out of luck. There isn't a way to quiet them down that I found. (They use a thin, metal concave disk than flips to being convex when pressed. Putting anything in there to quiet it down makes it lose all functionality.)
Step 3: Open Up the Switches
Open up the switch by inserting the tip of your knife into the clip of the switch cover and gently twisting the knife until it unlatches. Unlatch the other side, it should be easier.
Do this in an area where with dark flooring. That little white button likes to get away and it's really hard to find on a white floor.
Step 4: Press Down the Tab
Using your knife again, push the tab down to shorten the gap between the contacts. Test the switch and its loudness by pressing down on the cross member where the white button would normally press.
If you bend the tab down too far, just bend it back with the knife. The metal is quite malleable.
Step 5: Put the Cover Back On
Once you're satisfied with the sound of all your switches, put the covers back on them. You more than likely lost the white buttons, so you'll want to put them back into their covers using the knife to coax it into the slot. The side of the button with the flanges goes on the inner side of the slot.
ProTip: It's much easier to put the mouse on the cover than it is to put the cover on the mouse. (That dastardly white button!)
Step 6: You're Done
Enjoy your new Ninja Mouse! It's so quiet your boss will think you're being unproductive.
4 People Made This Project!
  • Pocket-Sized Contest
  • Pro Tips Challenge
    Pro Tips Challenge
  • Paper Contest 2018
    Paper Contest 2018
Followed the instructions and halved the sound level on both clicks. Excellent. Many thanks indeed.
At first I thought that it's just a troll post, but I've tried it and it REALLY WORKS xD Thank you so much for this!!!
I know I'm pretty late to the party but after successfully completing this mod the first time I decided to make my left click button even more quiet and ended up making it super hypersensitive after taking it of its little hinge thingies and bending it a little. I tried molding it back and put it back on the grooves but that's when it stop making the clicking noise and became hypersensitive. Please Help!
You can adjust the tab height highlighted in step 4. If you mean the whole swing arm got bent, I don't know what to tell you other that bend it back and get it to spring again. (You can also go to a thrift store and buy a cheap old mouse and scavenge another arm piece out of that.)
Wow thanks, ended up just grabbing an arm from another mouse... thanks for the quick response!
thank you it worked perfectly and now the buttons is very sensitive
