3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ninjabread Men
Ninjabread Men
After seeing a picture of some similar ninjabread men cutters by Fred & Friends on epicwinftw.com I HAD to have some. Not being one to just buy something, I thought I'd have a go at making my own using strips of 0.5mm stainless steel and a jig to bend it around.
Not being a dab hand with graphics software I twisted the arm of my friend gmjhowe to make me some outlines. The ninjas in the PDF he sent me back are pure awesome, and should be a wee bit easier to make than the shapes of the originals I got my inspiration from.
Once the artwork was done I could cut out a template to use to bend the strips of sheet steel I had bought into the desired shape.
Read on to see details on how to get the best result and how to make the all important template.
Step 1Tools, Materials & Ingredients
None of these are absolutely necessary, you should be able to get by with less, use your imagination! The steps after this one show how I used some of the below tools to make the ninjabread man production process smoother and easier.
Tools: ( a selection of, not all necessary)
  • tin snips
  • long nosed pliers
  • a fat, straight, round pen
  • a thin, straight, round  pen (a felt tip would be handy, since it can also write on steel)
  • gloves (may be useful if you have soft hands)
  • sand paper
  • a vice
  • a printer
  • a spot welder / pop rivets / araldite
Materials:
  • paper
  • ply wood (or acrylic)
Ingredients:
See step 13.
74 comments
1-40 of 74next »
Jun 20, 2011. 9:38 PMmysss says:
I'd have put the shinier side inside for the (probably slight?) decrease in friction. This is an awesome idea! Now we can make whatever cookie shapes we want!!
Nov 9, 2010. 10:26 PMSome Dork says:
These are great! Someone actually sent me a link for the "for sale" versions of these a few weeks back, I love that you devised a good way to "home bake" them, as it were. :)
Nov 7, 2010. 10:33 AMWingsandFences says:
Really nice! Love the ninjas, but really love the tut on how to create your own cookie cutters.
Oct 6, 2010. 3:16 AMsparkynz says:
Great project
Do you think I could make these cutters out of Acrylic Strip? It will be easier to bend using a heat gun /hairdryer.
I would mkae the templates out of MDF which would be a little taller than the acrylic strip.
Oct 29, 2010. 4:00 PMsparkynz says:
HIYA
Will have a go and let you know the results.
Mike look at this for a school project?
Can make other shapes, if the acrylic works out?
Oct 12, 2010. 12:00 PMThe House says:
Holy moses that's awesome.
Oct 4, 2010. 3:11 AMcandy924 says:
good work! i'm sure my son is gonna love them!
Oct 2, 2010. 10:33 PM8ntfrogn says:
would cooper and a scroll saw work for these?
I may just have to buy them but I want different poses. Thanks
Sep 30, 2010. 9:28 PM9ale7 says:
can you tell us more about the Laser cutter?
i like the end results on the acrylic :)
Oct 1, 2010. 12:01 PM9ale7 says:
hi, i would love to make my own one ;)
might be to much for a newbie, but i'm all fired up to make my CNC,
so whether you tell me about you're or how did you make the laser cut alone? (can it cut in a manual way without a CNC Router??)
and better to give me an idea about the budget :P
(by the way i did check you're blog but still can not find a picture or a post regarding the Laser Cut it self)
and thank u 4 the respond.
Oct 1, 2010. 1:12 PM9ale7 says:
wooow, way off the BUDGET !! for a first time ..
yet i would love to see you're post :)
Sep 24, 2010. 9:27 AMBroom says:
I've wanted to do this for YEARS!!!!, but didn't have the knowledge to work with bending metal. Lack of experience can equal timidity to try!
Thanks for the clues! It sounds much easier than I thought it would be.
Also, you can buy small pieces of aluminum flashing from DIY/plumbing/hardware stores, that would probably work well for this.
I'd join the lapped edges with either a metal "weld" epoxy like JB Weld, or by running a solder bead along them, because I don't have access to a spot welder.
Thanks again!
Sep 30, 2010. 4:34 PMsrilyk says:
You could use a rivet instead - if you did a pop rivet from the inside that could probably work without munging your cookies too bad.
Sep 30, 2010. 3:51 PMjjmcgaffey says:
Do be careful about what you use to connect them, since these will be used on food. I don't know JB Weld - how toxic is it? And if you solder, make sure it's lead-free. That sort of thing.
Not as important for these as for a bowl or baking pan, since they touch the food only for a short time, but still something to consider.
Sep 30, 2010. 9:23 PMBroom says:
Good points, jjmcgaffey. JB Weld is insoluble in water & alcohol, and after about 24 hrs has very low volatile content (outgassing), so it's food-safe.
Great point about the solder. Modern plumbing solder is silver-based, and therefore food-safe; electrician's solder may contain lead.
Sep 30, 2010. 10:29 PMdenniszel says:
Great job, , if you attach a long handle to the top of the cutter you can make ninja outline " cookies" , just heat some oil in pan and let the mold get hot, then dip in pancake mix being very careful not to let it flow over the top edge of the mold, since the mold is hot, it will slightly cook the batter, then take it out and put it in the frying pan, since the oil will be very hot , it will release the fried batter , just wait for it to fry a little, take it out and sprinkle some sugar on it and amaze your friends witha " how the hell this you do this" , below are pictures os similar mods and the resulting " cookie"
Sep 30, 2010. 5:37 PMtrophywife says:
i cannot 'favorite' this hard enough. nice work, sir!!
Sep 30, 2010. 9:55 AMe_doe19 says:
Thanks for posting this 'ible! I have thought before about fashioning my own cutters for various shapes I wanted but could not find. But I never knew exactly how to do the metal bending. Your photos about that are great and I'm looking forward to making all kinds of custom shapes now. Thanks again. : )
Sep 30, 2010. 10:26 AMbgepp1 says:
Very cool! Are these made from Tae-Kwon-Dough?
Brent Geppert
Sep 30, 2010. 11:17 AMFretka says:
omg.... that is funny !! :) lol
Sep 30, 2010. 7:10 AMFIClarityJane says:
Is there any chance you could please link me to the seller on ebay? Thanks!
Sep 30, 2010. 10:02 AMFIClarityJane says:
Thank-you! :D
Sep 30, 2010. 6:49 AMTinworm says:
A very cool instructable.
I liked the friendly tact used by Fredandfriends when they wrote to you and I like your response.
You are a creative guy, so I'd have thought that if you fancied selling templates for biscuit cutters, you'd be able to come up with lots of original and interesting shapes which would appeal.
Very impressive stuff; I feel inspired.
Thanks
Sep 30, 2010. 8:31 AMTinworm says:
Excellent news
Sep 30, 2010. 7:50 AMAeshir says:
Sep 26, 2010. 12:21 PMcowscankill says:
Best idea. Ever.
Sep 27, 2010. 11:25 AMfredandfriends says:
Dear Jayefuu, We recently became aware of your "DIY" version of an item we recently released called Ninjabread Men. We here at Fred love the Instructables community and all that it stands for. We have licensed a number of ideas from DIY designers that we felt would make great commercial products. Our company blog even has a section dedicated to Fred "hacks"- showcasing people that use our products in new and interesting ways. Many of these people go on to sell these new (original) creations- and we're cool with that. If $8 is too much for someone to spend on a set of cookie cutters and feel you can do create them yourself, more power to you.
We do have a little problem when someone creates an exact duplicate of our product and profits from that.
If we find an original idea on a craft or DIY blog, we immediately contact the designer to obtain rights to manufacture and distribute his or her idea.
The Ninjabread idea was licensed from an English designer, to whom we pay royalties for its use. Your actions directly affect his ability to make money, and possibly infringe on his copyright. I would therefore urge you to reconsider the sale of your templates.
And if, in the future you can come up with a new, original idea, we might be interested licensing it from you.
Sincerely,
Fred and Friends
1-40 of 74next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
236
Author:Jayefuu
I am currently undertaking a PhD at the University of Huddersfield, England, looking at novel techniques in dispersive white light interferometry. Feb - April 2012 I was an artist in residence at I...
more »
