3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Nintendo Controller MP3, Version 2.0
Step 9Crafting the Battery Compartment
I decided to use some scrap plastic from a broken controller to make an awesome battery compartment.
First, cut a 90 degree corner from a spare controller backing or some other piece of plastic. Make it a bit shorter than the AAA.
Next, place the AAA battery in the upper right corner of the controller.
Drop 4 or 5 drops of super glue to the bottom of the 90 degree piece and place it up to the battery once you have the battery in the right place. Make sure the tab of your 90 degree piece faces away from the battery.
From the Blue Ray gift card, I pulled off the battery holders. You can use any similar metal that conducts electricity and is bendable.
I trimmed the edges off and made it into one long rectangular piece.
I used a 4 to 5 inch long piece of 22 gauge wire to solder to the fabricated battery connection
Make 2 - one red, one black.
I replaced the battery, fit my battery leads, and twisted a cardboard Q-Tip into the open space between the battery lead and the screw post.
Cut the Q-Tip long enough to touch the bottom of the space but flush with the top of the screw post.
Fill the Q-Tip with a handful of drops of super glue. It will harden quickly and rocks as a filler!
( I used chunk of plastic previously which I had to trim down and test fit repeatedly - It still did not fit as nice as the Q-Tip filler!
Trim and fit the battery sticker from the Coby MP3 player if desired.
2 comments
Jul 14, 2009. 10:19 PMringleader369 says:
Is there any way to make it easier to change the battery? (want to make it as a gift and not have to keep changing the batteries for em' )
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:ryan97128
