3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Nintendo DS Lite Case - supercute quilted version with storage pockets
Step 5Make Pockets and Flaps
For clean edges and stronger pockets, all the pocket pieces and flaps are made by sewing together all four edges (minus a 1.5 inch opening) of a rectangle with right sides facing. Then, the rectangle is turned right side out (through the opening) and pressed smooth.
Quilted DS pocket:
Line up the edges of the 9 x 4.5 quilted square and the 9 x 4.5 un-quilted square, right sides facing. Sew along one long edge. Flip seam the right way and press.
DS flap:
Fold the 10 x 5 rectangle you cut from the accent fabric into a 10 x 2.5 rectangle. Following the method described at the top of this step, stitch around the three unfolded edges, leaving a 1.5 inch opening for turning. Turn right side out.
Pleat pocket (for games):
Fold the 6 x 3.5 rectangle you cut from the aqua fabric into a 3 x 3.5 rectangle. Following the method described at the top of this step, stitch around the three unfolded edges, leaving a 1.5 inch opening for turning. Turn right side out.
Flat pocket (for charger):
Fold the 6 x 6.5 rectangle you cut from the aqua fabric into a 6 x 3.25 rectangle. Following the method described at the top of this step, stitch around the three unfolded edges, leaving a 1.5 inch opening for turning. Turn right side out.
Two smaller flaps:
Fold the 5.5 x 4 rectangles you cut from the accent fabric into 4 x 2.25 rectangles. Following the method described at the top of this step, stitch around the three unfolded edges, leaving a 1.5 inch opening for turning. Turn right side out.
Press all rectangles flat
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:tumblingblocks
