Support DIY and Instructables : Become a Pro Member Today!
Nintendo Lunchbox
intro
introNintendo Lunchbox
I had a broken NES, a rotary tool, two small hinges, some glue and Alpha Flight's Sasquatch. What I ended up with was a lunchbox that gets all kinds of funny looks. This is my first project, and kinda sloppy. I only had about two hours to do the whole thing. I'm sure I'll improve it over time (add a latch and file down the rough edges some more) but for now, it holds my lunch admirably.
Nintendo Lunchbox
To View All Steps on one page,
Go Pro Today!
step 1Remove the guts
Opening the NES case and pulling out it's guts is pretty easy. Take out all the screws you can find and lift the parts out gently one at a time. The wires can be unplugge…
step 2Remove the wires
Removing the wires from the controller ports is a little more tricky. They will pop out with some effort, but you may just want to clip them off and file the sharper ends …
step 3Power and Reset buttons
Once you unscrew the circuit board that these are attached to, they pop off really easily. Save these so that you can glue them back into place later.
step 4The plastic posts
I wasn't ready for all these little plastic posts that are inside the bottom part of the case. I couldn't even fit a bag of chips in there like that.
step 5Rotary tool action
The best way I could think to deal with the posts was with gratuitously unsound use of a rotary tool and a a couple of cutting wheels. This was by far the longest part of …
step 6Better
Once the posts were cut off, I ground the nubs down with the rotary's sanding attachment. Now it's nice and roomy in there. I left the 6 larger posts intact since they we…
step 7Add hinges
Adding hinges was pretty simple. Just mark where the holes should go and drill carefully with your smallest bit. The plastic is very pliable and the screws go in very nea…
step 8Test the hinges
Test it to make sure that it opens and closes smoothly. Mine didn't the first time and I had to reposition the hinges. Also, notice the white boarder around the Power a…
step 9Pack it
Now put some lunch in there! You could be really silly and try to feed your sandwich through the old cartridge slot.
step 10Enjoy
Finally, put your new lunchbox in the office fridge (into which it fits nicely) and wait for your coworkers' reactions.
142 comments
1-50 of 142
Aug 10, 2008. 10:58 PMdanisreallycool says:
i dig the flavor, some ideas i was thinking about:
1) having the hinges on the back of the system, with some sort of clasping mechanism with the power/reset buttons.
2) this hinge-in-back could also let you put a strap in the cartridge slot for a handle.
3) any chance the hinges could be inside?
4) the red power LED for when its got food in it!
5) bonus points for some sort of sandwich protecting cartridge case
this is all just me being greedy, though. nice job either way.
Aug 14, 2008. 8:59 AMWills42 says:
Actually, I believe that you would have to modify the slot so that it would fit even a PB&J sandwich. The slot is just too thin that it would probably only fit one slice of bread. Although, you could just carry the slices in two separate slots and make the sandwich at school or wherever. Nice idea though.
Oct 14, 2009. 8:12 PMebayhax4u says:
 I made this over the weekend  when I was sick and the slotworks really well with sandwiches. For me, the sandwich fits perfectlyand if you cut the edges a bit, you can fit your sandwich in one of thecartridge holders. hope that helped you.
Aug 13, 2008. 2:02 PMLextone says:
You can put an internal hinge in there. What you are looking for is called a Continuous, or Piano, hinge.
You could also rig up a magnetic catch utilizing the power button.
The LED idea is cool too.
Good job Fluctifragus!
Sep 22, 2009. 7:39 PMimaluma says:
How does it stay shut? Do you have to just hold it carefully?
Aug 6, 2009. 10:32 AMMr. Brownie says:
This would be a cool bento!
Sep 6, 2009. 10:23 AMLargePaperCup says:
i second that
Aug 28, 2009. 2:07 PMredsoxdrummer says:
grate idea!!!But you to apart a nes dude!! i gess if it was broken............
Aug 29, 2009. 4:36 PMLance Mt. says:
I don't think i could bring myself to take apart a nes, broken or not. I just cant do it!
I really want one though.. ohhhhhhhhhhhhhhhh
Aug 31, 2009. 2:09 PMredsoxdrummer says:
agreed!!!!
Aug 10, 2009. 8:05 AMalphasmith says:
The only problem is you can't bring it to school without having to demonstrate it's lunchbox abilities.
Jul 12, 2009. 8:22 AMSkipperOf says:
This is a great project to do in coordination with 1up's portable game system. Now that case can do something useful! Its great, don't listen to the haters.
Jul 9, 2009. 12:53 PMMadrias357 says:
Now that is funny! I knew a friend who did something similar (major computer geek). He took a dead printer, gutted it, and made it into his lunchbox. Access food through the ink door, snacks through the paper-tray (that stupid flip door that holds your paper for all the world to see, well, his had room there for snacks and sodas.)
Was always funny to see a Canon printer in the fridge.
Jun 18, 2009. 10:51 AMRandomidiot says:
Hmm... Nice!
But couldn't you put the hinges on the back of the NES so you open it from the front and not the sides? that would look way cooler.
Mar 28, 2009. 4:04 AM89joho87 says:
What!? you destroyed your NES?! how can you do a such thing?
May 28, 2009. 1:48 PMSpartan104 says:
He said it was broken.
Apr 30, 2009. 4:48 PMxMIKEABx says:
if that nes wasnt broken i probably would've flipped out
Apr 28, 2009. 10:10 AMHairom says:
I absolutely love this idea. I can't wait to make my numerous Nintendos into something wonderful!
Apr 21, 2009. 12:36 PMmayney93 says:
Yumi 8bit apples
Mar 27, 2009. 7:28 AMbelgvr says:
LMAO, its awesome :D
now try to imagine your mom's face when she opend the refrigerator, and then: "NES" :O
hahahhaha
Mar 17, 2009. 1:54 PMfireFEIND67 says:
who's the guy helping with the tutorial in the pictures?
Feb 1, 2009. 1:41 PMmonopechamp says:
Hey this was such a good and easy Instructable I just did it to my NES.. very funny, when I take it to school (substitute teacher) and the other teachers get took back to the 1980's and like it they want one I am thinking about selling mine to them. they said they would pay like 50 bucks for them ha ha just for the nostalgic appeal to it.
Jan 25, 2009. 11:58 PMStevenMcFlyJr says:
haha ... sweet! ii should make one ...
Jan 24, 2009. 10:38 AMMexicanjedi says:
Sweet demo man!
Jan 13, 2009. 3:05 PMCapt. Fat says:
The Captian was here......
Jan 5, 2009. 12:28 PMFasteners says:
You can get a NES emulator for any other gaming system.
Aug 9, 2008. 11:59 AMrev4n says:
Not that, in theory, this isn't a cool mod, but dude... you just ruined an NES so you could put a sandwich in it. I don't care if it didn't work. The price to repair the NES is not likely going to be more than the amount of kittens you just killed by gutting it and putting it in your fridge.
Dec 23, 2008. 7:40 PMawang8 says:
Who cares? A NES is sooo out of date.
I don't care what the haters say. This is a cool 'ible and people should learn to appreciate things.
Oct 19, 2008. 8:11 PMvampflorian says:
lo lwho cares you get them for 10 bucks at cash converters and pawn shops he can just buy another one
Oct 11, 2008. 6:31 PMthoraxe says:
well i'm sure the nes could still be repaired, it just wouldnt have a case. i dont think the case is completely necessary for its operation
Aug 12, 2008. 9:50 PMtazmon122 says:
excellent point, and being "8 bit" by using a nes for a lunch box is neither cool nor retro nor funny. i feel like there are a million other things you could do with a nes then gut it and stick it in the freezer
Nov 22, 2008. 8:45 PMmg0930mg says:
Such as...
Nov 25, 2008. 12:37 AMtazmon122 says:
play it, flip it on its side, and add a clock motor, thus making a clock, sell it, place it on a shelf,and save it, decorate the outside i.e. paint it, put googly eyes on it. i personally am saving it, but my point was to say that is project is bad, and less creative than i hoped...it is up to you to figure it out, if you like it, then more power to you, but if you can think of more stuff, then do it...the nes is a powerful thing...i thought of one more thing, place it on it's side, and call it modern art
Nov 25, 2008. 12:20 PMmg0930mg says:
1. He couldn't play it, it was broken.
2. A clock's an ok idea.
3. You have good ideas, why don't you make an instructable. =D
Nov 26, 2008. 10:48 PMtazmon122 says:
mine works, i just don't play it...maybe i can get my friend to donate his
Aug 10, 2008. 6:46 PMchevyboy666 says:
Kittens?
Aug 10, 2008. 11:21 PMREA says:
every time you download music illegally the government kills a kitten. gutting an NES means he killed 5.2 million kittens. plus that sandwich looks petty nasty so thats another 2 million. and i cat tell what that fruit is so there goes another 500,000.ok so now he just killed 7.7 million and some extras for illegal downloads he may have done.
Aug 15, 2009. 4:12 AMendawmyke says:
Cats suck (jk i just dont like cats they're scarry lol)
Aug 10, 2008. 11:23 PMREA says:
and i think i see a trix yogurt so bye bye 10 million more!
death count: 17.7 million kittens
Aug 11, 2008. 5:23 PMpuppetfunk says:
Actually I think that's Horizon Organic Yogurt.
Aug 11, 2008. 7:10 PMREA says:
ORGANIC?!?!?!?!?!?!?!? make that 20 million then!
total: 37.7 million kittens
Aug 14, 2008. 2:58 PMpuppetfunk says:
That's like Half the entire cat population in America. At this rate cats should have been extinct 7 months ago.
Aug 15, 2008. 4:01 AMjespo0o says:
you got a point there.
Aug 15, 2008. 12:49 PMREA says:
and just think, thats more than 800,000 gallons of paint PETA would have thrown on the cat killers!
Aug 17, 2008. 1:43 AMjespo0o says:
HOLY HELL!
Aug 17, 2008. 6:35 PMREA says:
exactly! so, to save kittens and paint. only take game systems apart if they are beyond repair.
this message brought to you by the Public Service Announcement Committee.
Aug 18, 2008. 3:31 AMjespo0o says:
gotta agree with that.
Aug 10, 2008. 4:13 PMcraz meanman says:
lol!!!!
Aug 10, 2008. 3:17 PMbaneat says:
A NES is worth like £5 unboxed. Even less for just the system. We're not going to have a shortage because of the increase in demand of weird lunchboxes
1-50 of 142
Related
