Well, first of all, you need to assemble a few necessary items. These can be obtained either individually, or purchased as a package with or without your radio controlled car or truck. You will need the correct nitro fuel, a glow igniter, batteries for your radio transmitter and receiver, and a small screwdriver.
Have your glow igniter fully charged and ready to use. Make sure you have installed batteries in your controller (transmitter) and the car's on board receiver. Verify that they are functioning properly by operating the steering, throttle and brake. After all, you want to be able to control your RC car once it is running! Fill the car's fuel tank with the proper nitro fuel. Be careful fuel is extremely flammable and toxic! Check with your engine's manufacturer or your local hobby shop to make sure you are using the recommended nitro mix. 20% is the most popular. OK? Now we are ready to fire her up.
Clip the glow igniter to the glow plug located in the top of the engine cylinder head. Rotate the engine by whatever means your car or truck uses such as manual pull recoil, on board electric starter, drill operated shaft starter, or portable starter box. You may have to 'choke' the engine to initially supply fuel to the carburetor. You can easily do this by placing a finger over the exhaust outlet. Watch for fuel movement through the fuel hose so you know when fuel has reached the carburetor. You don't want to flood the engine!
Once the engine has started and is running smoothly, you can remove the glow igniter. Drive easy for a few minutes until the engine warms up a little. After warm up you may find it necessary to adjust the carburetor high speed needle, low speed needle, or idle speed set screw to maximize performance.
This might all seem intimidating to you, but it really isn't hard to learn with a little practice and patience. The sound of that high performance nitro engine springing to life makes it well worth the effort!
sources www.hobbiedown.com and actionvillage.com
Remove these ads by
Signing UpStep 1How to drive you Gas RC car.
Step1
Realize that your controller works just like the steering wheel on your regular car. When you move it to the left, your RC car moves to the left and when you push the controller to the right, your car moves to the right.
Step2
Drive as fast as you can the first few times you take your RC car onto a new track. This will help you get a feel for the track without worrying too much about making a mistake.
Step3
Stick to the middle of the track instead of trying to hug the edges. Your lap times might not be as good, but at least you won't drive your RC car right into one of the track barriers.
Step4
Look for lines or the areas of the track where more experienced racers drive their cars. This should give you an idea on how to lower your lap times.
Step5
Draft with other cars just as you would if you were racing NASCAR instead of driving an RC car. Not only can you increase your speed, but you can also see where other cars are running and what spots drivers are avoiding.
Step6
Be consistent any time you drive your RC car. The more time you spend racing and practicing, the better you'll get.
ive but most dont.
my firsth car had the same
4 -plugs until my shop gave me a new glowstick (glow plug ingnitor)
http://www.youtube.com/watch?v=ZykgJuKrNo4&feature=feedf
but now i want to make a car with ic engine and also remote controlled.....
so please give me detail information.....
may i get a kit for that car from any where?
if yes, then in how much cost?
SORRY FOR THE CAPS COMPUTER STUFFED
it is realy from a zenoa engine
i have the same on my 26cc gas car
