3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Nitrogen Triiodide
Nitrogen Triiodide
Odds are that you've seen a demonstration of this stuff before, most likely in your high school chemistry class. It is a highly sensitive contact explosive made from two ingredients ammonia and iodine crystals. It is so sensitive when dry it can be set off by a feather or even a fly. The last time I made this was years ago for a science project. It was the middle of winter and I had been setting off batches of this stuff in my backyard all day. When night fell it started lightly snowing, the snow flakes fell to the ground and set off minute traces of the NI3. The resulting snaps were loud enough to wake up my mom who then woke me up and told me to do something about it. I wasnt really sure what to do about it so I filled up a bucket of water and threw it out over the pavement, setting off hundreds of little snaps which each gave off tiny poofs of purple smoke.
It has got to be one of the most surreal memories I have, being out in the moonlight while snowflakes gently floated down, causing the dead silence to be broken by little purple snaps going off everywhere.
Heres the wiki for it nitrogen triiodide
http://en.wikipedia.org/wiki/Nitrogen_triiodide
Step 1Materials
Materials
Iodine crystals.
Can be bought on e-bay, unitednuclear.com, or http://shop.armorforensics.com/mm5/merchant.mvc?Screen=PROD&Store_Code=RedWop&Product_Code=1-2805&Category_Code=
That last one is a forensics website. Iodine crystals are used in a fingerprint lifting process called iodine fuming. As you can see on the label on the jar, the gas from the crystals has stained the paper to a dark purple color. Iodine gas is toxic, so do this experiment in a well ventilated area.
Ammonia
The purer the better. I use clear ammonia available almost anywhere. The store bought stuff is actually Ammonium hydroxide, meaning that it is ammonia dissolved in a ton of water. If for some reason you have access to highly concentrated ammonia the resulting nitrogen triiodide will be much more powerful, and therefore handled much more carefully.
A tupperware container
Coffee filters
134 comments
1-40 of 134next »
May 15, 2012. 8:22 AMimpulsegordon says:
so if you distill the water out of the ammonia hydroxide though osmosis (thats evaporating the water right?) would it purify the ammonia enough to be used for this?
Feb 28, 2007. 7:47 PMJollyrgr says:
COMMENT TO AUTHOR: Please add a disclaimer to wear saftey glasses, and gloves while playing with this stuff.
May 17, 2009. 10:22 PMjpoopdog says:
does liquid iodine work the same or must it be solid because i cant get iodine crystals/powder only iodine powder already dissolved in alchohol btw cloudy ammonia contains soap and soap as you know is slippery even when dry , and also as you know nitrogen triiodide is friction sensitive mix that with soap and its pretty much useless btw again can i evapourate the iodine solution to make powder and also can you get the soap out of the cloudy ammonia warning the government is slowly eradicating clear ammonia from grocery stores because they know that nitrogen triiodide can be made with it sorry this is so long but can you evapuorate cloudy ammonia into another bottle and will it pickup the ammonia in the vapure or will it be left behind with the soap as a salt?
Aug 5, 2011. 6:18 AMgrundisimo says:
If you don't know how to spell "evaporate" You probably shouldn't be messing with Nitrogen Triiodide.
Aug 5, 2011. 7:16 AMjpoopdog says:
because i mispelt a word i am incapable of handling NI3 why?
also, it would have been handy to know that it would have worked, since i spent 2 weeks trying to figure out how ammonia works, which i know now. i made some NI3 , and i cannot for the love of god understand what all this cafuffle is about.
Apr 11, 2012. 7:10 PMTv1996 says:
No, not because the word was misspelled. It's because iodine sublimates, not evaporates.
Apr 11, 2012. 7:24 PMjpoopdog says:
i have a good understanding of chemistry now, i know how to make it, but i dont want to anymore.
What i meant was could i evapourate iodine tincture and use that, but now i know the amount of iodine in tincuture is neglegeble. ide be better off extracting iodic acid from seaweed.
The best source of iodine is to simply buy potassium iodide, mix with hydrochloric acid, then add hydrogen peroxide, which results in what i beleive is roughly 70% by weight of the potassium iodide, in iodine crystals.
Ammonia is a very mysterious thing, as is hydrogen sulfides reaction with alkalis, which is more confusing, as it is an acid, yet does not follow the same rules as a typical acid-alkali neutralization .
anyone able to point me in the right direction to find out more about why ammonia behaves the way it does?
Jan 3, 2012. 8:08 AMbadassintheshadows says:
yeah... nitrogen is a whore.
Mar 25, 2011. 4:51 AMwinst_17 says:
Can we speed up the reaction of iodine crystals with amonium hydroxide by like, heating the mix?
Jul 9, 2009. 1:00 PMDr KAZ says:
Unlike DANGEROUS explosives, this SAFE explosive (it is a high explosive), is not easy to make as the ingredients are not available at every corner shop. Try as you may, nothing but the pure stuff will work. It is best synthesized by using the method suggested by Tetranitrate although the limit of 1g iodine set by him is not the absolute safety limit. I have done this in 20g batches (in a fume cupboard). A batch may be rolled into a ball (using gloves) and set upon a high place (like a 7th storey library roof) to dry for a few hours (use a Buchner Funnel to separate your crystals). To set this baby off, just release it from whatever you are holding it with. The 2m diameter brown ring left behind sublimes in an hour (weather permitting). Please: Be safe, wear safety glasses, gloves and at least an apron when playing with chemicals. NEVER play alone.
Jul 9, 2010. 8:06 AMemcelhannon says:
"Nothing but the pure stuff will work." With pure Iodide crystals, will the store bought amonium hydroxide work?
Dec 11, 2009. 11:46 AMDr KAZ says:
Add this:
I regularly hold "explosion chemistry" workshops for students. I take the utmost care not to ever injure anyone. However, during one of my workshops, a student held 0.5g of nitrogen triiodide on a sheet of paper, outside, in open air and was blown off his feet when a gust of wind blew the sheet of paper holding the explosive against his chest. He wore a lab coat, safety glasses and had long pants and closed shoes to aid in his protection. A sense of humour also aided in both of us coming frrom the experiment without any harm.
EMPHASIS: If you know how stuff works, be even more carefull than when you do not have a clue.
AND: Rather play with this than try to synthesize other lethal compounds of which you know nothing of.
Dec 9, 2009. 3:22 PMmettaurlover says:
What about making this stuff by the pound in small containers designed to strain out the liquid?
Dec 9, 2009. 10:30 PMDr KAZ says:
Could be possible, I'd scale it up slowly though. Remember, the crystals must be completely dry in order to detonate. That might prove technically difficult in some sort of sealed container. You'd also want to speak to your bank manager as iodine is not exactly the cheapest material around. Nonetheless, it is a viable idea.
Dec 10, 2009. 7:03 AMmettaurlover says:
True, but I know people. And I wouldn't actually need very much of the stuff. Juse using a film canister as the container, then carefully lidding it when it's dry after otherwise draining liquids.
Dec 9, 2008. 5:03 PMmazeka.14 says:
is there any way to make this stuff less sensitive so you could say, throw it??
Apr 17, 2009. 7:30 PMgenesis357 says:
well nitroglycerin is a sensitive explosive, and all the original dynamite was stabilized nitroglycerin. i would guess yes. maybe when the NI3 is in it's liquid stage, add flower or sawdust to soak it up. that's exactly how nitroglycerin use to be stabilized.
May 29, 2009. 11:59 AMmazeka.14 says:
cool, im gonna have to try that
Jan 15, 2010. 7:16 AMshawneegeek says:
Be careful if you do, because the military has looked into this and found it had no useful application just because of how unstable it is.  It's been recorded that slight gusts of wind can set this stuff off.
Jun 4, 2008. 8:24 PMthe_anaconda says:
would I be able to use iodine tablets like the ones used to purify water?
Jan 15, 2010. 7:13 AMshawneegeek says:
No, those water purification tabs don't work.  I tried it with the old ones even, before they switch to binary ingredents, and it still didn't work. But you can get iodine from walgreens that works.... hope this helps ya out, be safe.
May 29, 2009. 6:30 PMgenesis357 says:
I don't think that;s the right type of iodine. not sure though.
Sep 21, 2010. 11:35 PMAlpha Bravo says:
The iodine in water purifying tablets is usualy potassium iodide or a similar compound (which wouldn't react with the ammonia). But fear not the iodine can be extracted to crystals by reacting with acid. This can be very dangerous if done incorectly (producing clouds of iodine and acid gas; toxic AND corrosive :| ). I would recomend following this vid if you still want to do it; http://www.youtube.com/watch?v=ydYMZKgn9pE
Dec 9, 2009. 3:20 PMmettaurlover says:
I have a simple idea for a safer way to set this stuff off. I may post an 'ible on it once I've had a chance to test it out. It could also be used quite easily in a grenade.
Dec 11, 2009. 11:25 AMDr KAZ says:
"It could also be used quite easily in a grenade." It is glaringly obvious that you have never synthesized even a mg of this compound. Learn to respect chemicals before you attempt making gram quantities of high explosives, or any other chemical compound not found at the corner store, for that matter.
Please, should you try anything with this, rather consult the "old man" - I'd gladly help out with instructions, even send you the stuff, if you agree to be careful.
Dec 11, 2009. 1:42 PMmettaurlover says:
I was talking about my way of setting it off, not about the actual substance being used in a grenade.
Oct 21, 2009. 2:22 PMjam BD says:
Wow ha ha ha
soooooooo dangerous =D
Feb 12, 2008. 4:08 PMcanno says:
can i get this in Hong Kong cause i want to test out an idea with this stuff
May 9, 2008. 3:40 PMPbyrd says:
What idea are you talking about?
May 13, 2008. 6:27 PMcanno says:
the impact smoke bomb
Sep 12, 2008. 6:30 PMeskimojo says:
I think that this wouldn't work very well. The reaction is too fast in order to create enough smoke for a smoke bomb. Maybe you can find a way to use it as something along the lines of a percussion cap? Smoke bombs generally need a slow "cool" burn in order to generate enough smoke to be effective.
Jan 3, 2009. 1:56 PMItsTheHobbs says:
But, if you used a kno3 mixture, and used a small amount of this for ignition...
Oct 9, 2009. 4:16 PMItsTheHobbs says:
Cool!
Apr 17, 2009. 7:25 PMgenesis357 says:
NI3 won't produce enough heat to ignite a smoke bomb.
Apr 17, 2009. 7:47 PMItsTheHobbs says:
oh.
Apr 18, 2009. 7:52 AMgenesis357 says:
If you watch a NI3 detonation in slow motion, you will notice no flame. It's a good idea though. But NI3 doesn't really burn, it just decomposes rapidly.
Jan 3, 2009. 4:28 PMeskimojo says:
Read up a little and it seems that the reason this is basically just a chemistry classroom trick is that Nitroglycerine can use a "phlegmatizer" in order to adjust the sensitivity of it, nitrogen triiodide however doesn't take so well to them.
Jan 3, 2009. 4:24 PMeskimojo says:
truthfully, you could... depending on how hot the explosion is. I would probably use Potassium chlorate though, if I could get my hands on some. And by the sounds of it, smoke bombs are actually quite easy to make. You might even be able to make do mostly with kitchen-found items. Using this would still be foolhardy, it's far too sensitive. Technically you could do it, but you wouldn't even be able to get the mixture in a container, you'd have to set up a "smoke pile." It would be a mess and you'd be better off trying to use something else as a starting element.
1-40 of 134next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
331
Author:Tetranitrate
I'm attending NYU-Poly.
