3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Nixie Tube Music Visualizer
A hypnotizing music visualizer inspired by those little bars in the top of iTunes. Fourteen Russian IN-13 Nixie bargraph tubes are used as the display.
The length that each nixie tube lights up represents the volume of a certain frequency in the music, 7 different bands for both the left and right channels.
I designed and built this over a month my junior year in high school. This instructable will go over my design process and the construction, hopefully aiding anyone who wants to build one of their own.
Step 1Design Process
Design Process
The goal is to make an interesting display that would show the volume levels of various frequency bands in an audio signal, as in many music players and on the front of some hi-fi audio equipment. There are three major points the project would focus on:
  • Minimizing cost: In the process of designing the visualizer, I found this simple VU meter with a nixie display utilizing an exotic IC to convert an audio signal into a volume level. While convenient, it's manufactured by a small company, and each piece would cost over $5 (for me, nearly $80 in those alone!) For simplicity and for my wallet, this only uses simple, cheap, and mass-produced parts. Also because of cost, I decided that 10K ohm resistors would be used for just about everything, so I could buy a few hundred for around $3.
  • Analog only: Using a digital signal processor was a possibility, but programming a DSP is fairly difficult, and the cost of DACs for the input and ADCs to drive the output began to raise the price too far. So only analog parts such as op-amps and comparators would be used.
  • Adjustability: After Nixie IN-13 tubes were chosen as the display, I realized that the only documentation was in Russian (or poorly translated English) and not very informative. Not knowing anything at all about how much it took to light it up any specific length (aside from less than 4 milliamps), everything about this design would be adjustable.
48 comments
1-40 of 48next »
Apr 23, 2012. 5:32 AMagray9 says:
Dude if u could hook that up in your car that would be tight!
Aug 2, 2009. 6:59 PMalex-sharetskiy says:
great instructable, but a little too complex for my tastes and chance that you're going to sell pre-built circuit boards?
Apr 12, 2012. 8:41 PMimjustintime says:
Please do, I'm sure you could sell quite a few!
Dec 3, 2011. 9:51 PMdquinnell says:
I am very interested in building a project like this, the parts list says 170 (One Hundred and seventy) 10k resistors are used, is that a typo or are there really that many 10k resistors used? If i were to build a one channel visualizer, would i take this parts list and divide it by half (other than the parts where only 1 is used of course)?
Oct 25, 2011. 5:45 AMdjjoec says:
I would like to make one of these for my  Melbourne DJ hire company. What would the total cost be?
Aug 26, 2011. 11:25 AMwww.microbike.ie says:
basses should be on the left side but you have it reversed on the left EQ is it on purpose?
Oct 21, 2011. 10:35 AMimjustintime says:
Is there any way to add a couple more frequency bands? I have a 10 Band Stereo EQ that this would go nice with in a custom box. Does this use converted AC voltage or just a battery?
Sep 26, 2011. 3:33 AMKryptonite says:
This is incredible, what was the total cost of this project for you?
Jul 23, 2011. 8:53 PMben_xman says:
Wow! That's really impressive, especially for someone so close to my age! You should really consider going to MIT or CalTech. So anyhow, what made you want to use nixie tubes?
Oh, and I was wondering a couple things. Could you use, say, five LEDs instead of the tubes and make it small enough to fit in a pair of headphones (I could always add a bit to the sides, bottoms, or even the chord itself)? I was thinking of making a headset mod with a circular visualizer on the side. Any ideas? Thanks in advance! And good luck in the future!
Aug 31, 2011. 5:48 AMmangomango says:
i would love to have this also! or maybe something with a microphone so you could take it anywhere and have it listen to anything!
Jun 23, 2011. 7:07 AMData643 says:
Great Instructable, especially for a Freshman. I wish I knew electronics that well.
Jun 22, 2011. 8:20 PMgarywpalmer says:
Very nice indeed. When I was an Electronic Technician in the US Navy (early 1970's), one of my favorite pieces of equipment was a frequency analizer with a nixie tube read out. I'm glad to see nixie tubes making a comeback in a lot of projects.
Jun 22, 2011. 1:55 AMedwardholmes91 says:
Very nice! I'm jealous that I never made anything quite that impressive when I was at school in electronics! My final A2 project was a greenhouse climate control system. Never used that dot matrix board but it seems to be a nice compact solution. We had PCB manufacturing facilities at school so I was lucky enough to be able to make my PCBs there. If anyone is interested in the Design, Development and Manufacture of a PCB follow this link to a series of video that I made: http://bit.ly/iNr6Z4
Apr 20, 2011. 4:28 AMpostlife says:
Would it be possible to make one with more tubes? I am looking into building a 4' visualizer to mount to the front of my keyboard stand. Thanks.
Apr 21, 2011. 11:57 PMapplefanatic says:
i put it in my xbox hacking lol the audio from my xbox to go on the cover it looks so cool thanks :)
May 7, 2011. 9:58 AMCaseBoy says:
ohh post a pic
May 3, 2011. 9:06 AMMax "the bassist" Pratt says:
Ok i am building a bass guitar right now and was thinking 2 of those nixies would be perfect on either side of the 4 strings, so if anybody is interested in some 1 on 1 chatting about how this could be done i would really appreciate it
Apr 18, 2011. 11:44 PMcybervanig2000 says:
First of all, this is a very complex project for a junior in high school to accomplish. so bravo on that. (I barely had my soldering skills and basic circuits at that age) . Really a unique and amazing build. This would look really good with a more modern enclosure and of course with the right music.
Mar 11, 2011. 8:20 AMonlinemastering says:
Nice spectrum analyzer, cheers
online mastering
Dec 19, 2010. 2:06 PMtigerstickfigure says:
Wow, man! This is gorgeous! This instructable got me into both Nixies and Honeycut!
May 1, 2010. 4:12 PMStormrage says:
Its awesome... just im wondering where can i find those tubes, can it be bit simpler and  can it work with microphone?
Feb 11, 2010. 6:19 AMluhe98922 says:
Hi there! Could I use a more common LM339 voltage comparator instead of the ts3704 which is giving me a hard time to find?
Dec 11, 2009. 12:21 AMbman22 says:
I have been looking for exactly this for a different project i am working, my only problem is that i need a variable voltage between 0 and 5 volts instead of your 12v current system. Can anybody here help me in acheiving this. Its a bit over my head, so i would really appreciate some help.
Nov 1, 2009. 4:37 PMsatanklawz says:
Great project! I've ordered most of the same parts. What are the voltage requirements for the capacitors? You wouldn't happen to still have the parts list from mouser and digikey?
Nov 1, 2009. 5:53 PMsatanklawz says:
Based on a comment you made before, is the information below correct?
14x    100uF electrolytic polarized capacitor 25v
14x    4.7uF electrolytic polarized capacitor 25v
18x    1uF capacitor 25v
Are the below capacitors multilayer ceramic, or mica? Would ceramic suffice (I didn't see polarity noted for any of them)?
13x    .1uF capacitor (should this be 14?)
8x    .01uF capacitor
4x    1000pF capacitor
Oct 24, 2009. 2:41 PMalfredhenriksen says:
I love it!
Thank you for writing and shareing this project. :)
Oct 5, 2009. 10:53 AMfade400 says:
Does the value of Cin matter ?
Sep 15, 2009. 7:11 PMSmithjoe1 says:
You can probably use half the parts if you use LM3196 chips for the log to linear, they are identical to the circuit that is printed on the original post but cut it from 4 chips to 1 on each tube. I've got a set of IN9 tubes that I'll be building this with. But I'm having a hard time understanding the frequency splitters, how do you work out what resistors to use for each frequency?
Aug 28, 2009. 9:19 PMlindland1 says:
can i use 9 in tubes in sted of 14in X 13in
Aug 27, 2009. 12:41 PMszechuan53 says:
Aw man, this is soooo cool. Did you do this as a school proj or just for fun?
Jul 26, 2009. 3:04 PMlemonie says:
Really good looking - any plans to mount these in a case? L
Jul 27, 2009. 11:36 AMThe Ideanator says:
Well, measure 2+ times, cut once(unless you have wood to spare) I wanna put this in an old Victrola radio/record player, they would go together SOOOO well. Actually, I want to convert the whole thing to a steampunk-esque media center. Ooh! You could try to mount this in the side of a PC case! That would be cool.
Aug 21, 2009. 10:26 AMthepelton says:
As someone who works in wood myself, I can tell you that first, you should always buy a little more wood than you actually need for the project, since there is a possibility that somewhere in it is a defect or injury that you will have to work around. It is, after all, coming from living trees.
Aug 21, 2009. 10:23 AMthepelton says:
Fascinating. I had never heard of nixie bargraph tubes before. They look neat.
1-40 of 48next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:Senator Penguin(tchips.com)
