3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Nixie Tube Ornament
Nixie Tube Ornament
The Nixie Tube Ornament is a homage to the light-up&motion ornaments from the early 90's. The ornament looks cool on a tree and makes a great gift. Finally, a use for IN-12/15 top view tubes!
I used an IN-15A symbol nixie in this ornament. An IN-12 works great too.
A video of the ornament alone:
A video of the ornament in my tree. (Yes, the walls are changing color. I have the si-light system in my apartment: http://si-light.sourceforge.net )
Details you will find in this instructable:
1. A small high voltage power supply that runs the tube.
2. A tube carrier to mount the nixie tube in a socket so it can be changed.
3. Firmware that runs the power supply and changes the digit displayed on the tube.
Everything you need to make your own nixie tube ornament is included in the project archive:
1. Circuit board in Eagle (Cadsoft).
2. Compiled firmware HEX file, and Mikrobasic source for the free (demo) Mikro compiler.
3. This instructable in .odt (Open Office) format.
Step 1Design overview
Design overview
The nixie tube ornament has 3 main parts:
1. A power supply  boosts 5 volts to 180 volts for the nixie tube.
2. A tube driver  changes the lighted tube digit by grounding one of the 10 tube cathodes. I used the Russian KD155-whatever.
3. A microcontroller  a PIC microcontroller ties everything together  it runs the power supply and changes the digits shown in the nixie tube through a four wire interface to the tube driver IC (see previous).
33 comments
Nov 30, 2010. 10:05 AMmr-mishin says:
OOooo great. I'm from russia, and i realy surprise to see IN here=)
Jun 20, 2010. 2:24 PMTvmender says:
Thats really cool! I like the idea of a retro tree ornament, its a shame you didnt have a job lot of these and make a set of ornaments. I think they would look great all flashing away like they do with random characters. - Tvmender
Apr 11, 2009. 9:45 AMSaNjA2659 says:
Your nixie tube shows random characters insteard of numbers! I want this sort of nixies, too.
Feb 8, 2009. 3:08 AMuberdum05 says:
Yay somebody uses OpenOffice
Aug 11, 2008. 3:25 AMpanstar1 says:
(removed by author or community request)
Jan 13, 2009. 4:35 PMPie Ninja says:
Just wiki it.
Oct 24, 2008. 12:37 PMThelonelysandwitch says:
where did you get the multi tool?
Dec 20, 2006. 3:51 PMhallcp says:
It seems like an extraordinarily bad idea to go stringing high voltage on your Christmas tree, plus a poor use for what must be an almost extinct type of vacuum tube. Or am I missing something obvious?
Aug 9, 2008. 11:58 AMrocketman221 says:
this does seem like a bad idea if something were to short across the hv power supply it could set the tree on fire.
Jan 11, 2007. 7:36 PMmever says:
Technically, you really can’t say that high electrical voltage is dangerous because its not, electrical current is. That’s a common misconception. I don’t know what amount of current to expect from this project but from an electrical engineering standpoint, you can’t judge how dangerous something is based on voltage alone. The static electricity to hold a balloon to the wall after rubbing it on carpet a few times can create 10,000 volts easy but virtually no current. Another example is the old Van de Graaff Generators (the metal balls that make your hair stand on end). Remember the signs that say “Danger – High Voltage!” still mean “Danger”… but the “High Voltage” part was not suggested by an electrical engineer. So consult an electrical engineer before making your next sign for proper terminology ..haha, just kidding. Great instructable ian! This is some really nice work.
Apr 28, 2007. 2:09 PMstatic says:
I have a 5" BW battery powered TV, that most likely 5K volts inside the cabinet, safe to use unless the cabinet is opened or breached somehow. The same is true for tree ornament. I'm not so sure it's a poor use of what may be a rare device. What would a waste is for it to sit on a shelf for years and eventually tossed, because lack of demand. Ian did nice work, archiving is just as nicely. However the end product may not everybody's "cup of tee", I jut really don't see a hole lot of persons duplicating this project, thereby any depleting existing stock. I would think most persons looking to duplicate the ornament would chose an LED display
Jul 22, 2008. 12:56 AMDerin says:
VV W
Dec 27, 2007. 2:54 PMTJ 2 says:
Really cool project! too bad there arnt many of those types of vacuum tubes left though or I would have made one.
Dec 26, 2007. 7:08 AMthecheatscalc says:
That's pretty awesome! (love the knife too, aren't they great?) Love the nixie tubes, I have GOT to pick some of those up. so much better looking then leds.
Dec 25, 2007. 5:33 PMMadMechanicMike says:
hight voltage? exposed circuits? chrstmas tree? am i missing something?
Dec 15, 2007. 5:25 PMIamTheCreator says:
Nice tutorial, the SI light system would be cooler if it like changed the whole color of your wall though/ your walls were like huge monitors or somethin', ('sept that'd probly cost too much...) Anyways I give this a 10/10. :)
Sep 23, 2007. 1:59 AMJazzyTunes says:
COool! Perhaps, you could use the tubes for turning the tree to a hifi amplifier too. ;P
Jan 2, 2007. 7:43 AMsmidge147 says:
dude wherre did u get ur tool?
May 19, 2007. 12:22 AMJames (pseudo-geek) says:
is there a way to buy them withuot winning them?
Apr 18, 2007. 4:30 PMburokrat says:
russian nixie tube driver IC =)))
it was realy fun for me to read your description, because 155ЛÐ1 is 6 logical elements well known as NO. Look her analog for russian IC is sn7404.
Ether the less project is nice.
Dec 28, 2006. 1:15 PMcodeguy9 says:
Very cool. You did a very nice job on this.
Dec 26, 2006. 5:32 PMsanches says:
it is not russian :) but it is making the xmas tree look more techie. cool Vac tube:) electrifyin'!
Dec 25, 2006. 3:30 AMmutinyishell says:
hey, whered you get the instructables leatherman?
Dec 21, 2006. 7:44 AMJesus10555 says:
what is it saying, is it saying anything? or just random figures?
Dec 20, 2006. 12:34 PMmrmath says:
My Russian is pretty bad. What's it say?
Dec 20, 2006. 3:52 PMzachninme says:
Why do people think it is Russian?
Dec 20, 2006. 3:46 PMmrmath says:
So they are just random characters? Looks like it was something used in a calculator or something if that's the case.
Dec 20, 2006. 2:52 PMthadrien says:
Really great! I dont speak russian, but it is excellent!
Dec 20, 2006. 12:28 PMZujus says:
Realy nice job! ;)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
128
Author:ian(DangerousPrototypes.com)
