Nixie Watch Prototope_a V5. Full Datasheet
Published
Introduction: Nixie Watch Prototope_a V5. Full Datasheet
About: Steampunk artist, scientist, engineer
Hello.
This is full source code + datasheet + all what you need to build your own nixie watch.
This is new revision of model prototype_a. Now it is archiewed version.
This watch was build for my friend. Casing - brass, bracelett -leather.
If someone need inspiration or small worklog - write in coments, or check my instagram/FaceBook page.
Previous prototype_a alpha on instructables that use Transformer as power source https://www.instructables.com/id/Nixie-Watch-Proto... on this project source was lost due hdd milfunction
Build your own Steampunk Nixie watch
Note that wach work on hight voltage!!!
Note that youll need some junk from ebay!!!
Step 1: Characteristics
Rechargeable battery via micro-USB.
Description: This is Fully Assembled and Tested Nixie Watch with 4 Pieces IN-16 NOS Tubes + 1 Tube blink. Power By: DC 5V via rechargeable battery or via USB cord. Time before recharging: 12-16 hours in active mode or more than month in passive mode User Selectable: 24HH-MM-SS/ DD-MM-YY / Energy level/ Change on - off Dimension: Width 76mm x Height 50mm x Depth 26mm
(+- this depend of your casing. 3d printed or not\design etc)
Handmade!
Little video https://instagram.com/p/08F--GMSeH/?taken-by=prot...
On next Step datasheet
Step 2: Parts and Datasheet
Datasheet attached on top
Parts:
  • Capacitor 10 uF 4 pcx
  • Capacitor 100 nF 5 pcx
  • Capacitor 100 nF 3 pcx
  • Capacitor 1 nF 1 pcx
  • Zener diode 3V6 1 pcx
  • Diode ES1J 1 pcx
  • MicroUsb 1 pcx
  • inductor SCB0704-331М 330 uH 1 pcx
  • Transistor ZVN4525E6TA 1 pcx
  • Transisror MMBTA92 4 pcx
  • Transistor MMBTA42\PMBF107 16 pcx
  • Transistor BC847BS 1 pcx
  • Supervisor TLV431AIDBVR 1 pcx
  • RTC DS3231SN 1 pcx
  • Li-pol charging element TP4056 1 pcx
  • Buttons TM1103R25B-2500-TR 3 pcx
  • Atmega16a-AU 1 pcx
  • Nixie tube IN-16 4 pcx
  • Nixie tube IN-3 1 pcx
  • Resistor 100 k 6 pcx
  • Resistor 100 k 15 pcx
  • Resistor 10 k 25 pcx
  • Resistor 4.7 k 1 pcx
  • Resistor 2.2 k 3 pcx
  • Resistor 2.2 k 1 pcx
  • Resistor 1 M 4 pcx
  • Resistor 22 Ohm 1 pcx
  • Resistor 30 k 2 pcx
  • Thermoresistor NTC 10 k 1 pcx
  • Contacts PLLD1,27-80 1 pcx
  • Connectors PBD1,27-08S 4 pcx
  • Li-pol battery 643456M15 3.7V 1200mAh +PCB 1pcx
Step 3: PCB
Software http://diptrace.com/
On archive PCB
On archive Gerber
Step 4: Software
On archieve software
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    3 Comments
    That looks awesome. I love the steampunk aesthetic. Could you share some more about the details of the construction?
    On corners i used brass pipe. walls - 1mm brass sheet.
    all part was soldered using simple iron, or you can use dremel versatip
    https://www.instagram.com/p/BRJRcX9jyi0/?taken-by=... photo of casing from top
    https://www.instagram.com/p/BCu77Z8MSe3/?taken-by=...
    casing with laser-cutted acrylic glass (if you'll interesting - i have glass drowing)
    https://www.instagram.com/p/BBlA_UYsSfs/?taken-by=...
    on this photo youll see how parts was soldered
    https://www.instagram.com/p/yuyZJwsSVq/?taken-by=p...
    and just assembled casing without bracelett ears
    https://www.instagram.com/p/BGPk5A4sSaZ/?taken-by=...
    box-style design
    https://www.instagram.com/p/BFmPPrSMSSB/?taken-by=...
    folding and soldering. Button-style charging port
    PS. is you'll need worklog - i think ill make one in a few weeks
    ps2. Buttons i cut from solid brass using latre
    2 buttons D3.8mm X 3mm height
    1 button D9.8mm X3.5mm height
    Form of button like screw (rotate letter T)
