Introduction: Nixie Watch Prototype_C
Small worklog of my new nixie watch creation
I spend 6 month for building this watch.
Aluminium case. - Created from one solid piece of aluminium. Using lathe I cut 2 parts: top cover and casing
Quartz glass. - Glass cutted and polished from one solid block of quartz glass
Leather bracelet. - 28mm width
Docking station. - cutted from oak wood. On docking station installed mini-USB port for connectivity with charger.
Description:
Sensor adjustments - no mooving parts.
This is Fully Assembled and Tested Nixie Watch with 2 Pieces IN-16 NOS Tubes.
Power By: DC 5V via rechargeable battery or via Docking station.
Time before recharging: 6+ hours in active mode or more than 3+ month in passive mode
User Selectable: HH-MM / Change on - off / Charge left /Back-light colour
Dimension: Width 50mm x Depth 19mm
Docking station powered via USB. Oak Wood
Water resistance: Rainy weather will be not a problem.
Battery: Lithium-polymer, nonremovable. 400mah
Accuracy: +/- 1 second per month
Operating Temperature: -25 to +40°С / +3 to 105°F
Glass: Quartz glass !!!
Step 1:
First of all i'll ansver for your question abaut sharing drawings or cirquit:
Sorry byt it will be really impossible: 2 weeks ago my SSD drive died with all drawings... of all my creations
https://www.instagram.com/p/BOiJdTYAKV_
I have 5 finished boards left and i\ll use them for Steampunk art. (like on first photo)
Casing
Materials: Solid aluminium block, bicycle spokes, quartz glass, oak, little brass.
Equipment: Lathe, Dremel, file, time
Step 2: Circuits
Watch assembled from 4 circuits
1. Mainboard
2. Tube board
3. Left RGB led board
4. Right RGB led board
Components
1. Atmel microcontroller
2. Accelerometer or buttons
3. 2 batteries
4. no RTC
5. power supply
Working mode: Dynamic indication
Circuits i ordered on factury this time. I use board with multiple layers. Board thickness 0.75 mm
Step 3: And More Photos
And more photos from photoset it was really cold
Runner Up in the
Arduino Contest 2016
Runner Up in the
Green Electronics Contest 2016
Trash to Treasure Contest 2017
