Step 2Schematic and brief explination
As drawn, it is setup as fade in and fade out... for the instant on, fade out version you can remove 1 part and you might be okay, but that one part prevents a very short (time wise) short circuit when first triggered, and is generally a bad idea to omit the extra resistor, especially if your using current sensitive components to trigger the effect
So plan on 9 components no matter what, if you are feeling lucky you could go for 8, but its not advised (even though the short circuit is only very very brief)
How this works is as follows, when you switch +V the cap C1 is slowly filled though R1, if C1 is totally devoid of energy it is a short to ground, as time passes ( depending on the value of R1 vs C1) the capacitor becomes less and less of a short to ground, which is connected to the base of T1, as the current increases T1 passes more and more lighting up the LED
when you let go of the button voltage slowly comes from the storage of the capacitor, back though the led fading it out, BUT once you hit a certain point the current will only barley pass though the LED (leaks), this presents a problem as the cap can sustain a couple volts for a few minuets, which causes the LED to glow for a long time (in the scale of things)
SO! the second transistor comes in, and is setup in reverse so that when the voltage on the base (provided by the capacitor) stays high enough it switches the cap to ground, thus providing a path for the cap's current to discharge( otherwise the current is too weak to make a difference while the switch is held ) , the end effect is that the "fill up" time of the cap is roughly the same as its discharge rate, Instead of filling up in a second and never really fully discharging causing the led to glow for a long time
my 0.02USD
I hate to be critical, but the schematic shows a SPST (single pole single throw) switch, not a momentary closed pushbutton.
Otherwise, this is an excellent little project.
