3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
No-Experience-Necessary Board Breaking
  • last photo ←
I've always wanted to take karate lessons for basically just one reason - the board breaking. I never really understood what happened to one's body that allowed them to gain the super powers that enabled the average hand to break the formidable, structurally sound, wooden board.  To this day I'm still yet to take my first karate class, but I have been able to answer that question none the less...and, the answer is...absolutely nothing!  Board breaking is pretty darn easy, and in my opinion, just about anyone can do it.
I asked a friend of mine who IS a karate master if we could break boards one day.  She said sure, not asking if I had any karate experience...hmm, I guess she trusts me.
After rounding up some appropriate wooden boards and performing a few of those awkward slow motion "practice hits" where I visualized my hand going through the board, I was breaking boards left and right, at home just for fun, with friends at parties, and with the other members of the Instructables team at work.
I find the process of breaking boards to be far more pleasing than "hitting a pillow", which was my mothers suggestion of what I should do when I was a kid and wanted to break something.  The rush from breaking the board never gets old, and when you can one-up other inexperienced board breakers by adding second, and dare I say third boards into the mix, well, the fun just never has to stop.
***Please use this Instructable at your own risk and thoroughly consider this warning.  Although this Instructable encourages board breaking, and the author of this Instructable promotes all forms of board breaking by people with absolutely zero experience, all board breakers must understand that the risk of hurting yourself is real, probable, likely, and imminent.  If you break boards with the kind of limited understanding of technique and safety that I have, and share in this Instructable, please be prepared for the possible outcome of broken fingers, wrists, hands, elbows, arms and heads.***
Step 1Get Some Wood
Get Some Wood
Wide pine boards are the most readily available, inexpensive, and consistent type of wooden boards to break.
Pine is a pretty soft wood, so it's a good wood to mess around with, if like me, you don't have any experience with this sort of thing.  if you're looking for more of a challenge, try breaking a harder type of wood like oak, ash or walnut.
So, head on down to Home Depot and pick up a long length (96" for some real board breaking action) of 1" thick by 12" wide pine shelving.  Crosscut the shelving into smaller lengths so that your finished boards are around 10" x 12".  The size isn't crucial - anything in the ballpark will work.
Remember, actual dimensions of milled lumber are less then what they are sold for, so, just to be clear, the shelving that reads 1" thick on the tag, will actually be 3/4" thick when you measure it with a ruler.
This is an important point, since, if you're milling your own wood and attempt to karate chop through a 1" thick piece of wood that's actually 1" thick, it might be significantly more difficult.
164 comments
1-40 of 164next »
Dec 3, 2009. 12:00 PMscott f says:
The direction of the grain does matter, you want the wood to break around the hand or foot.  A board will always break along the grain lines.  Holders should never be holding the end grain of the wood, always the sides of the boards.
If you are hitting with a palm strike, the grain should be vertical.  For a chop, the grain goes the same direction as the hand.
Yes, one board is easy, but you can still get hurt.  I wouldn't do more than one without proper instruction.
Apr 29, 2011. 2:33 PMurtlesquirt says:
This insults me. I have broken boards before (in tae kwon do), and you definately need expierience. You need a good technique too.
Apr 30, 2012. 7:26 PMJulia_mother says:
It only insults those who believe it is a test of skill, which it is not because anyone can do it
May 9, 2012. 2:07 PMurtlesquirt says:
With practice.
May 9, 2012. 9:11 PMJulia_mother says:
No practice. it take a little pysche mentality.
My daughter and I did this is my husband's wood shop
He shown us how
No practice or martial arts for us
Dec 3, 2009. 2:22 PMSteve Colebrook says:
 The trick to more than one board is to put 'spacers' between them usually 5mm or 7mm-ish. Try challenging an "expert" with two boards flush togrther... they wont even attempt it.
May 9, 2012. 2:11 PMurtlesquirt says:
I have seen an orange belt break two boards flush.
May 9, 2012. 9:03 PMJulia_mother says:
Isn't orange belt a low rank? Like 2nd or 3rd?
Goes to show, no experience needed to break
Jul 19, 2010. 4:37 PMsway says:
Many people have already pointed out how completely and utterly wrong you are. Still, I have to add my voice, being a woman who can break 3 boards no problem NO SPACERS. I'm not a black belt, I was able to do that as a blue belt. Please don't present your information as fact when you are clearly wrong.
Apr 30, 2012. 7:38 PMJulia_mother says:
I think these boards were "hand-selected" per the softness of the wood, the widest of grain, the specialize dimensions. Spacers make it easy, but proper material selection is a must
May 1, 2012. 7:53 AMSteve Colebrook says:
Thanks... Thin pieces of dry wood... wide grain,,, sure... Get ANY of these black or blue belt to break a piece of one inch thick Australian red gum or... better still, two, I'll be surprised. One and a half inch pine perhaps??? Or... two pieces of any wood, held together say one inch each, grain crossed and I hold them??? Videos please,,,
May 1, 2012. 7:07 PMJulia_mother says:
Of course there is a "trick" to it. The problem with some martial arts/artists, they have to show "credibility" or "ability" and not knowing the "physics" behind what they do, they somewhat stroke a ego by these demonstrations.
Not all martial arts/artists perform breaking (misrepresentation) to demonstrate their skills
Jun 22, 2010. 8:46 PMquesoman says:
No. sorry but your wrong. im not even an expert and i slammed my foot through 2 peices of wood with no spacers. would have done 3 but we didnt have enough
Dec 4, 2009. 8:14 AMNathan_ says:
Are you kidding me? I've done Taekwondo for 7 years and I break three boards somewhat regularly with no spacers. Pics or it didn't happen? Covered.
In both pictures I weigh just over 120 pounds. Breaking three boards with a palm heel, elbow strike, or hammer fist isn't hard for someone who has trained for a while.. I train with other people that are a lot better than I am -- one guy did a 6 board break a couple years past.
It's cool if you want to inform people on something. A lot of people do use spacers. It makes breaking two boards almost as easy as one. But please don't claim that an "expert" can't. I could do three 11"x12" boards when I was 15.
Jun 22, 2010. 8:49 PMquesoman says:
At least someone has some knowledge of martial arts here. At the age of 10 i was a 2nd degree black belt. i could be 3rd or 4th now but i joinded scouts so now im too buisy.
Dec 10, 2009. 12:21 PMtheRIAA says:
That first picture is awesome, the two little kids in training getting blown away lol
Jul 19, 2010. 4:39 PMsway says:
Those 2 little kids are black belts. I can't be sure but when of them appears to be 2nd degree. Although the stripes may indicate his progress towards 2nd degree.
Dec 9, 2009. 6:06 PMMrMystery96 says:
as a second degree black belt in tang soo do (sister style to tae kwon do), i agree with you. it's a fairly simple thing breaking a board. placement, force, inertia, etc, all play into it. I've done plenty of routine breaks, and at most, i think i did six 1" boards without spacers. and i'm not completely sure but i think most of the people here have the spacers concept backwards. adding spacers should increase diffficulty in the break as the energy is being disperesed through the first board, and is severely limited into the following boards. In any case, this whole mess is a stereotypical "contest" if you may. (oh and by the way, i'm 13.)
Dec 6, 2009. 8:40 PMsneasle says:
i did karate for many many years, and nathan is quite correct, we routinely do more then one board, back to back, with no spacers.
I think the most I ever went through was four back to back, that did hurt.
Now, when you get to brick and concrete, spacers become much more common.
Frankly, I find it amazing that this has gotten as much praise as it has. It is very, very easy to hurt yourself doing this. There are many things that go into a proper break, board selection, grain direction, hand formation, hand placement, and proper form and movement. Yes, it can seem rather simple, but doing it right carries a lot less risk.
While pine is normally very easy to break, if you pick the wrong board, you can easily break your hand. Sap/moisture content is very important, especially for the inexperienced and for multi-board breaks. A board that is too wet or has too much sap will fight you all the way. I've had boards with so much sap/moisture that my instructors had a hard going through them. The trick to a board like that is to throw it in the microwave for a little while. Notice, I said a little while. If you leave it in too long, you drop the moisture content to a point so low that the person can snap it in half while holding that, which will kill the 'cool' factor pretty fast.
I have not seen anyone do any other type of wood, but please inform yourself before you try this at home.
Dec 9, 2009. 1:05 PMd2j5 says:
if you like this you should see the people who can break an iron rod with their head O_o. i saw some people do it on t.v. and it takes years or practise and training. im sorry but i forget the training method but i think the show  i saw it on is called fight quest? im not shure though.
Dec 3, 2009. 6:53 PMhitman_kiwi says:
 How thick are these boards you are talking about (not the spacers) because I had to punch through 3 for my Red Belt with no spacers.
Feb 4, 2012. 9:17 PMnunchucker says:
when we do gradings we use plasic re-breakables that slide back together because they are much more consistant than wooden boards, come in four thicknesses and the thick ones are often harder to break than wood. wooden baords we use for demos because it looks more impressive.
May 9, 2012. 9:09 PMJulia_mother says:
I had allowed my husband to read that^^
He is into carpentry/cabinet making for over 30 years.
He said there is no possible way that the thicker re-breakable is harder to break, or harder than wood.
He said it frankly:
If they use a thicker re-breakable, simply try the same thickness in wood. The wood would be harder than the re-breakable.
Also, he had said that the wooden boards have to be the right size.
Too short, it wont flex a little and thus is harder to break.
He said it is all in the selection of wood and sizes
Dec 13, 2009. 12:21 AMFred the Penguin says:
I did 10 2cm thick boards at my black belt grading, and that was after everything else.
Jun 22, 2010. 8:44 PMquesoman says:
I did 2 inches of solid wood at my black belt testing. then again at my 2nd degree black bet testing.
May 1, 2012. 7:11 PMJulia_mother says:
If you were in the US, standard lumber does not come 2 inches thick. Besides, wood isn't that "solid"
Apr 30, 2012. 7:41 PMJulia_mother says:
My husband works in carpentry. I bet you could not break the 2 inch boards he would provide you.
May 18, 2010. 10:33 PMKGood says:
This is really just simple physics. To say you need to take any sort of martial arts class to do this is pretty inaccurate. At most you'd need to learn a technique which, as seen in the videos, is rudimentary. Even then, you don't need more than a quick physics lesson.
Let's start with the idea of the force. You want to put as much force as you can into the boards. In the instructions you stated that you should hit with the heel of your hand...which works, but it is more efficient to strike with your knuckles or use a chop to try to strike with that bone at the base of your pinky, because the skin and fat tissue of the palm increase the time over which the action takes place, which is key; however it's probably a lot more painful :P
Next, the stance: This does matter because you are trying to build up as much force and momentum to transfer to the board. It is also key that the person holding the board locks his/her arms so the momentum is not transfered to them. Keeping the foot corresponding to the striking hand forward, you want to move your arm as quickly as possible and even attempt to lock your arm at contact if possible. Now, martial arts instructors tell you to follow through, which is wrong. When you follow through, you increase the duration of the strike, reducing the momentum transfered (sorry that I'm just throwing around terms, but you get the idea). In fact, upon contact you should immediately jerk your arm backwards. Fighters (boxing and MMA) use this technique for the same purpose. A long punch to the face hurts, but I guarantee a quick jab to the face would hurt a lot more.
I hope this helps! It's cool to think that almost every principal of martial arts is gained from physics. If you understand physics, you can probably excel at martial arts.
Apr 30, 2012. 7:35 PMJulia_mother says:
From my research, physics is what it is all about. For example; the BBC had a documentary called "Shaolin Physics" where so-called feats from so-called monks were examined to be those of physics, and nothing more
Aug 23, 2010. 8:49 PMturpie says:
The reason we tell students to follow through is because otherwise they stop at the surface of the board and don't break it. This is also important if the board holder allows any give as you need to get past that as well.
I can see how the jerk backwards would add to the "explosiveness" of the strike and will have to try that myself.
Cheers, Paul (Taekwondo 1st gup)
May 23, 2010. 6:54 AMcerealfreak says:
Whilst an understanding of physics is very helpful and used throughtout most martial arts training a good physcist does not necessarily make a good martial artist. Martial arts takes skill and having the knowledge doesn't always transfer to practice.
Apr 30, 2012. 7:37 PMJulia_mother says:
I agree and disagree. A good physicist can break boards, but may not have fighting skill. But a good martial artist can have good physics and may or may not have good fighting skill
Apr 30, 2012. 7:33 PMJulia_mother says:
I think that board breaking or other martial art demos like this is fake. I think it really is not a test of skill. Nor do I believe that it requires any training. I am going to tell you why-
My 11-year-old daughter is enrolled in dance. She has a 12-year-old “puppy love” boyfriend. I say “puppy love” because they knew each other since infant daycare and they are not seriously in love.
Her so-called boyfriend is enrolled in Karate. Now, I cannot mention the type of Karate because I do not know the differences.
He was preparing for his next level or belt thingy. He had to practice hitting a plastic board that could be re-fastened. Upon his next level test, he was to break a real board. We were invited to visit his test.
After the arrival of all in attendance, his instructor informed everyone not to try this at home and without proper training. His instructor stated that it was a great test of skill and had required much training to accomplish.
All of the Karate students performed their breaks well and past their tests. Afterwards, we were mingling among students and visitors alike. The instructor approached us and somewhat like a used car salesman, suggested that I enroll my daughter in his Karate school.
He said, with much training, she could get the skill to perform the breaks just like those who have done this day. My daughter is a bold person at such a young age; she had asked one of the Karate instructors if she could break one right now. The Karate instructor told her no and said that she needed much training and skill to be able to do it. Later, without knowing, the Head Instructor asked if anyone would dare to try the simplist of boards
Being the rebel she is, before anyone could stop her, she went up to a advance board that was still set-up, she brought down her hand really fast, and with a yell, she easily broke the board.
Sensing others who witness this in awe, immediately the previous Karate instructor removed the wood, its set up, and told us to get off the “floor”, the area of practice. As we were leaving, I told the instructor that the breaking thingy was not a test of skill and it did not require much training. As all there knew this to be true.
Later, the head instructor would try to convince us to enroll. Stating that my daughter had potential
Jun 6, 2011. 4:01 PMSuperhobo40 says:
The one thing I would add is for the holder to turn their head away so they don't get a friendly flying board to the face.
Apr 29, 2011. 2:38 PMurtlesquirt says:
NICE AXE KICK!!!!!!!!!!
Apr 29, 2011. 2:36 PMurtlesquirt says:
Allways lock out the arms. bend your knees, so if it doesnt break, shock is absorbed. That authors stance is pretty bad too. you hold it on the top and bottom.
Jan 27, 2011. 12:01 PMbowmaster says:
Here's a site that has instructions on how to train so you can break a concrete slab: http://www.karatebreaking.com/main.html
Nov 26, 2010. 2:36 PMLivStoleYourPie says:
The expression on your face... i died laughing
Oct 31, 2010. 8:04 AManibioman says:
that is a really cute baby
Aug 12, 2010. 9:10 PMduder145 says:
FALCON PAWNCH!
1-40 of 164next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
896
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
