- make it strong
- use all 4 feet by 8 feet (actually 49" by 97") of one MDF board with virtually zero waste
- keep it simple (dimensional lumber & lap/butt joints)
- keep it inexpensive
- PROFIT (ha ok, metaphorically speaking)
Remove these ads by
Signing UpStep 1: The Design
To keep it simple the frame is from dimensional lumber and attached by lap and butt joints and I spent a good deal of time determining their optimal placement and making sure I'd have screws in the right places to maximize the strength and long-term durability of this work bench. Check out the pictures for details as it'd be too confusing to explain.
Design Notes
- I intentionally placed the front 2x6 legs inside of the top frame so that I'd have a perfect rectangle on all edges of the bench top. This also means the top frame is flush with the walls where I placed the bench.
- The shelf is not as deep as the top so that when you stand in front of it you won't hit your shins on the shelf
- The are 4 legs so that the bench can stand on its own should I need to move it for any reason.
- The overall dimensions for this bench are: 96 inches wide, 27.5 inches deep, 40 inches high. Make it as wide as is comfortable for your space, like in a kitchen: there's no such thing as too much 'counter space.'
Whatever width your MDF (or plywood) is you'll want to find two numbers that have a difference of 7 and together add up to the total. Based on this you'll know where to cut (rip) your 4x8 piece in two.
For Example:
48" = 27.5" top + 20.5" shelf
49" = 28" top + 21" shelf
The reason for this is the "6 inch side" of the 2x6 is actually 5 1/2 inches and "4 inch side" of the 2x4 is 1 1/2 inches, which totals ... 7 inches. Hopefully from this explanation and the pictures you can decipher what I mean. I broke a cardinal rule of carpentry by not measuring first. I assumed the 4ftx8ft piece of MDF I bought was 48x96 but it was actually 49x97. I think they do this so that if you drop the MDF on it's edge in transport you can still strip it down an inch on any side.
Height
My 2 cents about how to choose the right overall bench height:
- Your purpose for the bench - do you want things at hip height so you don't need to bend over? OR will you need to get weight/leverage with what may be on the bench top?
- Obviously the answer to #1 changes based on your personal height.
Visit Our Store »
Go Pro Today »
Two other differences I add for my benches ~
* a double thickness of the MDF/Paricleboard/Plywood top along the front half to give a stronger top, with a "tool well" along the back.
* I also make a stronger leg arrangement, so there's no movement or flexing with any serious bashing..[ Also, with a span of more than 6 feet or so I would add a third set of legs in the middle..].
I like to make allowance in designing a bench to have a metalworking vice or small anvil mounted square over one of the legs, so it doesn't bounce during serious work.. And for woodworking vice(s), towards either end.
I will try to put together an 'instructable' when next I build a bench, because the ones I'm currently using are more than a couple of decades old..
You have just convinced me of how important it is for me to build my own bench...an enjoyable read, well documented, easy to understand....I can not say enough good things about this bench, :)
TY for sharing Sir.
