This is the same technology used in those ovens that have the glass panel over the controls, but they use ICs. The principal is the same however, they both detect (I think) the small electrical signals that people give off and amplifies this to a useful level. If this is wrong correct me, but all I know is that this works.
(This design works great for LEDs. I am making a touch LED flashlight that runs off rechargeable batteries, but I am not sure what batteries to get yet.)
Remove these ads by
Signing UpStep 1Parts
-4 x 2N3906 PNP transistors or similar (note below about transistors)
-1 x 1N914 diodes
-1 x 10v 1000uF capacitor (keep the voltage below 10v / Caps rated voltage or it will
explode!)
-1 x Barrel jack
-1 x 9v 300ma adapter
-1 x 120 Ohm resistor (Brown, red, brown)
-1 x Ceramic capacitor
-some shield wire (I don't use it because I don't have any but if you do use it!)
-some copper clad is nice to have but not needed
-ugly perf board
-Breadboard/protoboard are handy as well
Tools:
-solder
-soldering iron
-tin snips for copper clad and ugly perf board
*Note: The transistors I used are random transistors similar to 2N3906 but I live in Canada and can only get a package of transistors "similar" to 2N3906 so protoboards are good to test this out on. Mine are bi polar and let some electricity through one way all the time wether they are off or turned around let no electricity through when off. Test the different combinations to get the way that works best. 2N3906 should work fine in this circuit though I have not tried it.
how can i wire this into the input of a PIC?
pic 12f629 to be exact
thanks
See my blog here.http://watsonseblog.blogspot.com/2010/12/2010-dec-27.html
I am interested to know more about the experiment ini.can I know with more details, what are the types of components needed to make this touch sensor .. thanks, hope to answer.
This maybe can be used in another project to make it even cooler : Table-for-Electronic-Dreams (http://www.instructables.com/id/Table-for-Electronic-Dreams/)
What do you think, would it work?
If your still having problems comment again and I will do what I can to fix it...
Thanks
Try removing the resistor first and test the output, if you really need more up the adapter power. You should be safe with 12v 500ma, all the parts should handle that, but make sure the capacitor is above 12v, the one I used is only 10v and would explode.
If you have any other questions feel free to ask.
