3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
No-Knead Brick Oven-style Pizza
Step 6Pizza Time!
Pizza Time!
Now you're ready to make some pizza!
1. Make sure to place your pizza stone on the bottom most rack. If you have a convection oven, you can place the stone right on the floor of the oven. I've always made pizza with a stone, so if you don't have one, you're on your own.
2. Preheat oven to 500 F. That's as high as my oven goes, but if yours goes higher you can try even hotter temperatures. I never have, cause I can't. Once you've reached temperature let the stone get hot for 15-30 minutes. Rumor has it that that's a good thing to do.
3. Shape the dough. You could try hand-tossing or hand-stretching. It takes practice but is supposed to be worth it because the crust will be better formed. Again, see that Good Eats episode for the technique. I have low ceilings, so I use this French style rolling pin. It's also worked out pretty good so far.
4. Give the paddle a shake to make sure the dough didn't stick. If it does stick, add more flour underneath. Sticking is bad. It will make the transfer to the oven a whole heap of big trouble.
5. Add toppings. Remember: Less is More! Here I brushed on some olive-oil, with a dusting of kosher salt and fresh-cracked pepper, some diced ham and pepperoni, and mozzarella cheese.
6. Slide the pizza off the paddle onto the hot stone. Be gentle but firm. Before transferring to the oven, I like to give the paddle another shake. It helps get a feel for the inertia needed to slide it off, and sometimes cheese will come off. It's better for the cheese to fall off on the counter than on the stone, or else the cheese could fuse the pizza to the stone and make extraction difficult.
7. Wait ~5 minutes and the pizza should be baked!
8. Basically do the opposite of what you did to get the pizza into the oven, to get the pizza out of the oven.
9. Wait ~5 minutes to let the pizza cool and the cheese to settle down.
10. You're done. You can cut it up and eat it now. Or roll it up and smoke it or however you prefer.
2 comments
Sep 2, 2009. 1:47 PMAmzing44 says:
I've baked pizzas on parchment paper, I roll the dough on the parchment then transfer (carefully) to a preheated pizza pan I have waiting in the oven. Depending on the size I'm making, I either carry (very carefully) by the parchment edges or slide pizza and parchment onto a cutting board and then slide onto the pizza pan in the oven, (I don't have a stone yet)! Great tips, thanks very much Mike!
Aug 29, 2009. 10:09 AMmikejr02301 says:
THIS SOUNDS GOOD. sOMETIMES I USE CORN MEAL ON MY PADDLE TO KEEP THE DOUGH FROM sticking. Mike
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:whinehurst
On a cold spring morning in the mid-1980's, amidst thunderclaps of a torrential downpour, in the gray light of early dawn, I was born. And then some stuff happened, and now here I am.
