No Mess Yogurt Making
This is the easiest way to make your own fresh yogurt. I make it everyday- it's just that simple! It has saved me so much money and you can also just as easily make a spreadable yogurt cheese from the technique.
Whole milk produces a bit more than non-fat and is also quite a bit thicker when finished. I like a really thick yogurt so I usually strain out a lot of the whey when I'm done. The whey strains out quicker in the non-fat than the whole, but again you're left with less of a yield that way.
Step 1What you will need.
What you will need.
All you need to make your yogurt is:
- milk
- a large pot
- a glass jar with a lid (sterile)
- a starter (can be a couple tablespoons from store bought yogurt with live cultures)
- a spoon (sterile)
- a candy thermometer (optional)
- a wash cloth (optional)
80 comments
1-40 of 80next »
Jan 21, 2012. 2:36 AMRay Power says:
Thanks spuds, for the great instructable (the simple ones are the best). I've made a few batches already but I'm wondering: If I use UHT milk can I skip the milk heating step? I believe UHT stands for ultra high temperature and refers to the pasteurization of the milk. It has a fairly long shelf life and is not refrigerated until opened.
Sep 24, 2008. 6:31 PMquinault says:
I tried, it become too sour to drink.
Jan 12, 2012. 4:05 PMKringlur says:
Add sugar and vanilla? People normally add sugar to plain yoghurt when eating anyway.
Nov 2, 2011. 11:38 AMcoorodden says:
Did as you said with towel on the bottom and water half way up. Broke my jar. Lost my good rich raw milk. What did I do wrong? I started with cool water in the pot, turned the ceramic burner on medium, then on high. It was fine at medium.
May 26, 2011. 8:27 AMBlaik says:
Another method that works well and especially in making bigger batches (I normally do about a half gallon at a time) is to get a cheap styrofoam cooler and put your jars in there and then fill with warm/hot water to keep the temp where you want it. The insulation of the cooler keeps the water at temp w/o any need for adjustment (at least with mine) for about 2 hrs, but I keep my water on the lower end of the temp range, so if you did it warmer I'm sure it'd stay warm longer,
May 30, 2010. 10:01 PMkensbest says:
How Much?
Apr 20, 2011. 10:23 AMjamina says:
1 - 2 tsp should be plenty.
Apr 20, 2011. 10:22 AMjamina says:
If you're using unpasteurized milk, heating it to 185 essentially defeats the purpose of using unpasteurized milk to begin with. Most sources state that heating to just under 110 is perfectly fine for raw milk, and you retain the benefits of the raw milk cultures.
Store bought milk is full of weird stuff though, so I'd heat the hell out of it just to be safe.
Oct 30, 2008. 8:22 AMmguer133 says:
What a WAIST of energy! Using your oven vent for 4/12 hours, warming the milk before processing and then putting it straight into the fridge to cool down (doing so, warming up the whole fridge!). Where do you think global warming comes from.... Why not using a yoghurt machine that will keep your yoghurt starter / milk base warm for the same time? It's much more energy efficient and you don't end up wasting your money and proper energy. Please, keep things simple and efficient.
Apr 19, 2011. 3:49 AMoakspoor says:
Simple and efficient doesn't involve buying yet another single purpose machine.
Apr 19, 2011. 4:34 AMmguer133 says:
This is very true, unless you can use this type of low heating machine for yogurt, cheese or just keeping something warm (yeast).
That being said, a yogurt machine can easily be found at car boot sales for under 10$.
I make yogurt or cheese every week and it's only the two of use.
Apr 19, 2011. 7:07 AMoakspoor says:
My point is that wrapping in towels, placing the ferment in a cooler is more efficient and much simpler. If you want to complicate it a bit, put a container of hot water in the cooler as well to act as a heat sink. I use this process with great results for fermenting yogurt, wine, sauerkraut, raising dough, etc. I love my yeasties!
When you are finished with the yogurt, you can take the towels and cooler out to the beech or for a picnic.
Yes I've seen those yogurt machines cheap at yard sales. I couldn't justify even this small expense and energy use compared to insulating methods that have served our ancestors so well.
Nov 28, 2009. 1:59 AMms_jane says:
 too bad you misspelled "waste". apparently you "waisted" 18 years of teh edumacatshunz.
good instructable!
Dec 22, 2010. 6:43 AMmguer133 says:
misspelling when you are originally a none English speaker is not that important, you got the point, didn't you?
And btw, can you speak any other language...?
Jan 11, 2011. 1:47 AMmooo ham add says:
quack!!!
Apr 16, 2011. 5:39 AMThe_Cloaked_One says:
Okay, I followed this to a key, but when I got up this morning and pulled the yoghurt out of the oven, it is all just liquid still. And my dad forgot it was in there and heated up to 285 for a minute............is it dead?
Apr 19, 2011. 3:44 AMoakspoor says:
You should be able to start over with this batch. Just warm it to the incubation temp and add more starter. Then tape a note to the oven dial to remind Dad you have a project going.
Sep 22, 2009. 3:00 AMpstuart says:
If you are starting with pasteurized milk then bacteria shouldn't be an issue. That said, this step helps denature the milk proteins which makes for a much thicker, creamier yogurt.
Apr 9, 2011. 5:55 PMThe_Cloaked_One says:
It's not that it's the bacteria in the milk itself, its external bacteria in the instruments that can mess with the fermentation. They do it for the same reason they do in making beer and wine.
Apr 9, 2011. 5:56 PMThe_Cloaked_One says:
And it can be that the milk was contaminated by bacteria in the air.
Jan 13, 2011. 2:51 AMdimitris1 says:
Also why do your take out of the refrigerator the starter?
Jan 13, 2011. 2:49 AMdimitris1 says:
By turning your oven to warm, how this results to avoid temperature fluctuation since the yogurt is placed into the refrigerator.
Btw thanks for sharing with us this simple process to make yogurt.
Jan 11, 2011. 1:49 AMmooo ham add says:
thanks for helping me finally make pizza you guys :D
Sep 13, 2008. 11:05 AMfriezer says:
I'm not following something... do you leave your oven on all night for the incubation phase when you do this?
Jul 5, 2010. 4:07 AMbeanco says:
There is no need for the oven to be on at all! I jus made a batch, I simply heated the milk, let it cool, mixed in a couple tablespoons of yogurt placed it all in a jar, put the lid on loosely, ie. i just laid it on and stuck it in the oven because it was not in the way on the counter . I could have just left it out but I need the counter for making bread.... turned out just fine. I did not/do not have a thermometer, I did it by feel. Ppl have been making yogurt far longer than heat measuring devices and electricity and ovens have existed.
Feb 17, 2010. 3:12 AMwokwithme says:
Why don't you try Kefir Cultures(grains)? Works in 24 hours without the need for oven.
Jan 28, 2010. 5:25 AMCargilB says:
Ive been wanting to do this for ages, hav ei known how easy it was i would never have waiting this long!
I am into the whole eat raw thing and was wondering if the scalding of the milk is a necessary process? Would it work if I used fresh raw milk?
Also what cultures can I use if I don’t want to use shop bought yoghurt?
Feb 16, 2010. 9:07 AMlubinka says:
You DO need to boil the milk - I've tried it otherwise (for the same reasons with you) and it doesn't work.
Oct 1, 2009. 11:20 PMm3harri says:
I wonder if powdered milk can be used
Dec 11, 2009. 8:04 PMcfuse says:
Yes, I use powdered milk (exclusively - for reasons of economy. It is way cheaper than real milk is, and the end product is just as good).
You can use some, or all powdered in your mix, and the real beauty is that I don't have to strain my yoghurt like the author does - I just start out with double or triple the amount of milk powder for making milk.
Jan 9, 2009. 9:03 PMosp001 says:
I use a digital thermometer probe ($20 here in the US) with an alarm; I put the milk on low heat, and the alarm goes off at 185F. There's no need to boil it, and makes cleaning the pot easier. There's no reason to stir if you keep the temperature low enough. Secondly, when you need to cool it down, either just let it stand, or put it in a pan of water in the sink. That'll keep from heating up your refrigerator. Third, if you have an electric oven (no pilot light), check the temperature inside when you just leave the bulb on. Ours stays right at the perfect temperature for making yogurt. Pop it inside, leave the light on, and let it ferment for 24 hours. Works great.
Dec 11, 2008. 3:34 AMmtjohnson6 says:
RE: My post on 10/24/2008. I tried the Jello and...it was a MESS!!! The knox gelatin did work just fine but regular Jello was a horrible mistake. Next, I need to try pudding. I have some banana cream in my cabinet that I want to use. I plan to whip up a batch this weekend. So I will post once I know the outcome. ~me
Dec 11, 2008. 3:37 AMmtjohnson6 says:
See my post on 9/20/2008. The comment below this one is regarding that post not the 10/24 post. Sorry!!
Me
Oct 26, 2008. 7:27 PMRomaida says:
Thanks for the instructable. I made some and its great! How long will it keep in the fridge? I don't want to eat spoiled yogurt... yuck!
Sep 20, 2008. 7:57 AMmtjohnson6 says:
OK...from my exhaustive search for yogurt recipes online...I found that several use gelatin to thicken them. So, I have decided that I might try a little Lemon Jello to flavor/sweeten/thicken mine. I am going to add it to the cooled milk before I incubate it. Does anyone see any potential problems with that? The kids and I are going to whip up a batch today, I will post our recipe and instructions tomorrow. If I am feeling REALLY adventurous...I might post my own Instructable...uhmmmm....So, tune in tomorrow kids at the same bat time on the same bat channel...BAM!!! ZONK!! ZOWIEEEEEE!! "Holy Bat Yogurt Batman" :-)
Oct 23, 2008. 7:06 PMvelvetjones says:
Alton Brown adds powdered milk to his to thicken. How did the jello work?
1-40 of 80next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
51
Author:Poe-tate-o
Mother of two, one seven month old and one husband. I love to make things and to collaborate with other crafters.
