No Power? No Problem!
40,352
533
29
Posted
Introduction: No Power? No Problem!
This simple and extremely helpful device will help you get connected with low power consumption devices after a natural disaster, blackout, or if you want to go somewhere off the grid, such as camping. You can even add a small solar panel to trickle charge the battery.
Step 1: Materials and Tools
The materials you need for this awesome build are :
- Deep Cycle Battery (measured in amp hours)
- Inverter (in my case, it's a pure sine wave(the kind of power the grid provides))
- Charge Controller
- Wire
- AC Recipticle and Cover Plate
- DC Power Jack
- A few Switches
- End Cut Off of Extension Cord
Optional:
- Outdoor Outlet Cover (needs the metal box to the right of it)
- Volt Meter (not needed and mine broke during the build)
- Momentary Switch for Volt Meter (you don't want that thing to drain your battery)
- 12v USB Adapter (if your inverter doesn't have one)
Step 2: Fit the Battery in the Box
The battery size and capacity is up to you but just make sure you can fit the battery in the box you buy. (Make sure you take measurements into the store, I ended up having to return one that would not fit my battery.) Even better still, you can design and create your own box out of wood, or if you're feeling extremely ambicious, you can 3D print one!
Step 3: Ports and Switches and Meters, Oh My!
The next step is to figure out where all of those pesky connections and switches will fit to your liking. Here I have them laid out in the design I want to create. I have drawn, in pencil, where I want to drill holes. I finally drilled the holes and fitted the components. Also, sorry I forgot to take a picture of me cutting the hole for the outlet but a Dremel "buzzed" through that task easily.
Step 4: It's Electric! Boogie, Woogie.
This part can get a little tricky, but if you have any experience in electronic circuits, this will be a breeze. Turn your multimeter on continunity mode (the setting that makes your device beep when the two leads are touched together). put one lead on one side of the extension cord and match that up with the correct hole on the plug connector. Remember which one was which and then screw the wire onto the AC receptacle. Follow the same step for the other connection. Make ABSOLUTELY POSITIVE that you have the correct wires in the correct place or you may risk damaging our electronics. I have included a schematic of all of the connections for your convenience.
Step 5: Test It Out!
With any luck, you should have power! If you don't, make sure everything is connected correctly and the switch on the inverter itself is on. I had a ton of fun making this project and I hope you guys make it as well. Good luck and if you have any questions, feel free to put them in the comments.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
27 Comments
Pretty neat! Check out my diy for a wiring time saver. I bet it would help you, and feel free to vote?
Also liked the Volt Meter idea. Nice not to have to grab your DVM every time you want to know what's in the "Tank". Those LCD's are cheap on ebay too . Also on ebay et al and my favorite are the LED 7 segment displays for about $2-3 ea. Have only 2 wires...the voltage source powers them . My favorite is the 3 -30 v display wired in series with a momentary pushbutton. Just push read and release. Love these but never put one on my own emergency power box.
I built 2 of these about 20 years ago inside a 12 X 12 X 6" electrical box. Still have 1 today. Purpose for designing it was mainly Texas storms and I have access to 17Ah Batteries. Used cheap 50 W Inverter. Mounted Swivel Socket on top (so it could be layed down flat) , Handle and pushbutton switch on top. Only use CF Lights. Bet it would do even better on todays LED Lamps. My lamps drew 200mA and would run for a long time. On my first unit was socket for a Wall Wart Power Supply ,,through a dropping resistor and diode kept the battery topped off. My second unit just kept it charged with a float charger from Harbor Freight. Makes a pretty decent work light too. Thought about a Patient long time ago but I can't tell you how many categories it fit into. See someone had a concern of running the Battery down completely. Any Inverter I used had a built in low voltage (around 10.4 v) cutoff. Don't stop building...jw
Handy circuit but do not expect too much from that little battery.
They have hydrogen gas converters for boats. This device changes the Hydrogen to H@O or water(then put a pad in bottom to increase the surface area for evaporation)
My concern would be gas buildup inside the box when you are charging. I can easily see this setup exploding. Hydrogen and oxygen are given off while the battery is charging.
Drill a few holes in the box?
ANY hydrogen/oxygen buildup is dangerous, outside the box is best.
The best bet would be to wire a 12v computer fan in parallel with the inverter so that fan ins't constantly running and any fumes that build up would be blown out immediately.
Best bet would be charging the battery outside the case completely, in the open, preferrably outdoors.
