3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
No Screws or Holes Pull Up Bar / Door Gym
This is a tutorial on how to make a doorway pull-up bar that does not require holes in any door frames or walls to mount it; which makes it perfect for college dorms or other temporary living quarters. It pushes against the door at two different points when weight is applied to safely wedge itself into the frame without the use of screws or bolts. It has an estimated maximum capacity load of 300 lbs. It allows for wide, regular, close, and hammer-grip pull-ups and chin-ups. Some of the work for this instructable are inspired by Shenandoah of http://www.angelfire.com/ny5/shenandoah/Grunt/Bodyweight.html and other commercial products on the market.
Step 1Measurements
Measurements
We need to measure the width and depth of the door to be used. Most door frames will more or less have the same general dimensions, but it is important for weight distribution. Look at the pictures for more details.
59 comments
1-40 of 59next »
Aug 22, 2011. 9:53 AMabadfart says:
you could also hang a old military duffel bag full of cloths off of it for a punching bag
Jun 9, 2011. 11:22 AMdismissie says:
this is great- I've been wanting to put up a bar-
Mar 11, 2011. 9:35 AMmwhit13 says:
Very awesome man. i gota give you props on that. a little expensive compared to the 25 bucks at walmart but i will probably build it anyways just to say i made it. but of course i wont take credit for your ingenuity.
Thanks for the idea.
matt
Nov 22, 2010. 4:08 PMmr.squeakers says:
how much did this cost
Oct 17, 2010. 3:44 PMrodrigoslima says:
Great instructable! i print it, write down the parts and went to the hardware store... but it was way to expensive to build! (at least here in brazil...), they dont sell small pieces of stell pipe, only the full 236inches piece, for around U$ 60, not nomentioning the joints..., I would spend more than U$100 and still need to pay some one to cut and prepare the pipe pieces, I even tried an alternative, with two sets of a flange bolt attached to the ceeling, with a L curve attached to it, an 3 way joint on the end, with another L curve, but even that would be to expensive... i will need to stick to my old doorframe bar... :-(
Nov 2, 2009. 12:16 PMallorem says:
Just put 2 flanges on end of pipes and attach flanges to ferring strip to distribute weight on wall
Oct 13, 2009. 2:23 PMbassclarinet23 says:
This is a great instructable, but I could never trust my construction skills...I'd be afraid I'd fall or rip the trim off of the wall.
Sep 17, 2009. 3:19 PMdaniel4383 says:
Great instructable. I used this because i have a 42 1/2" doorway and nothing they offer commercially will fit it. Works like a charm.
Feb 28, 2009. 10:15 AMwwlaveck says:
Great idea . . . when I get ready to redo my weight room (i.e. start to work out) I plan to build this. What about using semi hard rubber balls cut in half for wall protectors?
Sep 3, 2009. 8:39 PMH3xx says:
tennis balls.
Aug 22, 2009. 1:54 PMDivendren says:
Sounds like a good Idea, but it would probably do something to your wall after a little bit of long term usage. Like a little rounded indent, nothing serious.
Jul 23, 2009. 1:31 PMfreerunnin1 says:
its almost exactly like that iron gym thing there advertising from Argos... yours will probably last longer
Aug 27, 2008. 10:10 AMTransquesta says:
Don't get me wrong, this is an excellent idea (and a not-too-shabby Instructable to boot), but I prefer the sto'bought variety simply because I want somebody I can sue into oblivion should the whole mechanism fail and I find myself on the floor in searing pain. I know, I know, call me picky. :-)
Jul 8, 2009. 12:40 PMstrykker5400 says:
you are whats wrong with america.
Jul 8, 2009. 1:58 PMTransquesta says:
What? Little old ME is what's wrong with Amurrhicuh? I thought it were 'dem towel heads 'r somethin' Dude, get a grip (and perhaps a little education). I was JOKING.
Sep 2, 2008. 4:32 PMcompletegeek says:
If you weigh enough to break the 3/4 galvanized pipe I doubt you can do many pull ups anyways.......picky. lol.
Sep 13, 2008. 6:53 AMsmithy813 says:
especially with a pipe assembly and part of your wall coming down on top of you
Sep 16, 2008. 4:52 AMsmithy813 says:
i have complet confidance with your assembaly, pipes don't usualy break, no, i just don't trust strength of completegeek and defdon delta's walls
May 24, 2009. 9:31 AMironforger33 says:
Thanks for the great idea, I made one from 3/4" black pipe from Lowe's for about $55. My door was a bit narrow, so I added a 3" nipple on each side between the 4-way and the 45 degree to make the wide grip a bit wider. Thanks again for the great instructable!
Apr 24, 2009. 5:35 PMthoraxe says:
you can do crunches with this too, just put it on the floor in the door and hook your feet under
Mar 30, 2009. 6:08 PMAnarchistAsian says:
no no you guys, it's all about the IRON GYM
Mar 22, 2009. 5:25 PMHellchild says:
haha, this is the cheaper way to get an Iron gym.
Jan 18, 2009. 2:26 AMerich06 says:
Thanks for a very good idea built one for my son he works out on it every day. Thanks once again. Erich (South Africa)
Jan 10, 2009. 1:47 AMjoat_mon_99 says:
How much do all the materials cost?
Oct 15, 2008. 6:09 AMtalonsblade says:
question, would it not be better to put a bar across the back side of it(the part that goes onto the wall above the door frame). that way it distributes the weight across the entire length, not just two points. I am not being mean or anything, just trying to ensure I don't damage my landlords drywall, obviously you would pad the bar.
Nov 3, 2008. 9:32 PMcahodge says:
not only that, but it would not be possible to assemble. You run into a "closed circuit" and the last connection would not be possible to assemble (without a wielding torch). The piece you suggest would form a circle with piece for chin-up bar, making it impossible to complete
Oct 16, 2008. 9:14 AMtalonsblade says:
good point about the couplings, i didnt think about that.
Sep 20, 2008. 8:21 PMmoreyrd says:
This is great and I am really thinking of making one. One question for all....If I damage any part of my door openings with this, my wife will kick me out. Has anyone had any issues with damage after using it for a while? I am about 195lbs. Thanks, moreyrd
Sep 8, 2008. 9:07 PMLudaChri5 says:
this is hella sick man. as soon as i have some extra money and make myself one. and i might take a cue from ritchie7 below me and go with 1/2 in pipe. i checked out your "final" product with the all the wrappings; very clean. cant wait to do mine.
Sep 6, 2008. 9:02 PMritchie7 says:
Thanks, this is great. I just built one from 1/2 in pipe instead of 3/4. Two different home depot's did not have the 4 way (cross coupling). I way 210lbs at least, and even the 1/2 in. pipe is fine. I used black pipe (like gas pipe), which was slightly cheaper, but not much. Except for the cross coupling, which they only had in galvanized. I bought all the parts to make a 3/4 rig as well, but will have to wait to find the cross coupling. The 3/4 will fit my hands better, and on both I will probably add another 4 to six inch nipple to make it even wider, because the 45 is hard to hold for me, although the 3/4 version will probably be a little easier. This is dirty work, as the pipe I bought was lubricated. Initially I thought I may be able to build this by just hand tightening, but I had to use the pipe wrenches and fortunately had a couple. Thanks again. ... this is cool. Now I just need to use it! Oh, btw 24in only fits into one of my door frames which has two swinging doors, because on a normal one, the door gets in the way. I may be able to tighten it down more and get it to fit in my normal doors.
Sep 7, 2008. 2:54 PMritchie7 says:
Here are the pics. I admit that I didn't read it fully, because I rushed off to home depot thinking they were closing soon. I just printed out the parts page. But I had measured the inside of the door jamb which was 28 inches. Fortunately, I just bought the 24" bar that you listed. The thing is, I didn't account for the open door protruding into the door space, and the couplings and threads take up some space, and for me it is the side of the couplings, that are slightly wider than the bar. So, be aware that an open door will take up some space; measure from that to the other opening, and so do threads and couplings. In my case I have a 28" door opening with two swinging doors that reduce the opening to 26 inches, and then threads and couplings make it so the 24" bar just barely fits while rubbing on the open doors and scuffing them slightly. You can see the 90 elbows touching the open door. It made it though;)
1-40 of 59next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:DEFDOM DELTA
