Introduction: No-Sew Foam Pouch
Hi everyone! This my first instructable and it's a simple DIY tutorial which you can use to make simple small pouches in no time! It's easy and is perfect for beginners.
Step 1: Prepare Your Materials.
You'll need:
- Foamic sheets in desired color
- White paint (optional, for decorating)
- Stapler (with staples, of course)
- Paintbrush (of course if paint is used)
- Tape (optional, for decorating)
- Scissors
- Pencil
- Ruler
Step 2: Draw and Cut Out the Size and Shape of the Pouch
Use a pencil and ruler to measure and to draw out the final shape of the pouch. If you are using a single large sheet, fold the sheet in half, so after cutting out you get two pieces.
Step 3: Decorate
I taped four stripes of tape at an equal distance and then I started painting the portion white. It took a bit of time to dry. Then I took off the tape. You can decorate it as you like.
Step 4: Staple It Up
Start stapling your pouch. Make sure that the the lower staples are close. The ones on the sides should be close to, but they are not as important as the lower ones are because most of the weight of your items in the pouch depends on them.
Step 5: That's It! Enjoy!
You can use it to keep any light weighted item. It can also be used as a pouch for your phone.
