Step 6Prepare the Motor
2. Cut one small cable. Strip half an inch of insulation to both ends (use a cutter with extreme caution, then pull the plastic away with your teeth).
3. Bend one end.
4+5. Insert the bent end into the hole of one motor's connector. Hold at the connector and twist the cable.
Repeat 2 to 5 with another longer cable.
6. strip the insulation at opposite sides of both cables, and bend the ends.
Add Comment
