Introduction: Maker Safety: No Spill Superglue
Picture of Maker Safety: No Spill Superglue
Superglue is one of the most important discoveries of the last century. It is amazing at sticking things together, its quick, its strong, it cures with a tight joint, what more could you want.
Well one of the downsides is that to get a long life out of your glue it needs to be stored in the fridge. That's not a problem! However, super glue nearly always lives in the door which normally sees a lot of opening and closing action. The result is that it ends up on its side ad glue always uses out of the bottle into the cap. A very common fault! So frustrated that I need to use maul grips to open my superglue to fix a project I set about finding a solution to the problem.
Voila, a scrap piece of foam has cured my distress, this is how I did it.
Step 1: Collect Your Tools, or Find Something to Hand.
Picture of Collect Your Tools, or Find Something to Hand.
For this fix, I found some second hand foam from my store room, a craft knife, an offending bottle of superglue. A pen is also very useful for marking the bottom of the superglue bottle, its nice to know where to cut.
Step 2: Cut a Well for Your Glue
Picture of Cut a Well for Your Glue
So I cut a square of foam and then marked up the bottom of the glue container by drawing around the super glue bottle. I then carefully used the craft knife to cut a hole, it doesn't have to be pretty as the foam will expand to grip onto the bottle, which is a desired outcome.
Step 3: Throw It in the Fridge and Be Happy Knowing Its Much Harder to Knock Over.
Picture of Throw It in the Fridge and Be Happy Knowing Its Much Harder to Knock Over.
That;s it you now have a simple and effective solution for the super glue bottle rattling around in the fridge door. No more lids glued shut, access your glue when you want and in an easy manner.
Best of luck and keep gluing.
Constructed (author)2015-08-23
I didn't even know superglue had to be stored on the fridge
Yonatan24 (author)Constructed2015-12-09
Same here..
satoko68 (author)2015-09-08
Like other people, I didn't know superglue should be kept in the fridge either! Definitely making use of this hack to keep all of my carrier oils upright in the fridge too, because that's where I keep them all to prevent rancidity. Unfortunately, they do get knocked over, which can create a h*ll of a mess. No to mention the waste of expensive, hard-to-find oils, which always guts me.
Thanks!
oldschoolwood (author)2015-08-24
Heck ! I did not know that super glue should be chilled for better life . Thanks !
grannyjones (author)2015-08-24
For small items in the fridge, I make a little pocket out of duck tape. Line the pocket with a piece of disposable water bottle, and stick it where it is easy to reach/see. Great for that little tube of minced ginger, too. Pick a color of tape that looks pretty in the fridge.
drmcube (author)2015-08-23
thanks, you gave me ideas how to store my superglue
r_anderson_c (author)2015-08-23
Brilliant! I wasn't aware super glue needed to be stored in fridge either. Maybe my next bottle will last longer. Thank you!
verence (author)2015-08-20
Well done! Simple but effective. A place for everything and everything at it's place!
About This Instructable
3,508views
30favorites
License:
More by CovMakerDad:Setup Apple Airport3 In 1 RemoteUse The Right Bit For Your Screw
Add instructable to:
