No Weld Bicycle Trailer Hitch
 by frenzy
Featured
This is a complementary instructable to the No Weld Bike Trailer. This instructable will show you a quick air hose coupling based trailer hitch, that connects to that trailer.
Step 1: Supplies
The supply list for this hitch is well under 5 bucks, here is what i used:
1 Male Airhose coupling
1 1/4" bolt
1 1/4" nut
1 U bolt (1 and 1/4")
Drill
Drill bits necessary to complete the job.
seaplanecfi says: Aug 1, 2010. 9:38 PM
That's a really ingenious coupling method, I like it! HOWEVER, a similar seatpost hitch that we've been using on a cart at local glider field wants to tip the bike over whenever we're stopped, because the hitch attach point is too high. Have you encountered that?
glorybe in reply to seaplanecfiMay 27, 2012. 8:42 PM
Are you certain it is not the center of gravity of the trailer that is trying to tilt the bike? Also, is the front of the trailer a bit heavier than the rear of the trailer? It needs to be.
For bikes with a steel seat stem simply buying a plumbing T and slipping it over the seat post might be a good start for a hitch. That should allow easy left right movement for a trailer and the other end of the tube could take care of the up and down movement. With a perfect sized T you could use the air hose connector easily. Or drill a hole through the middle nipple on the T such that a cotter pin can secure the tongue to the fitting.
pteranosaur in reply to seaplanecfiAug 16, 2010. 1:30 PM
Common to 'tall' hitches-also have the same situ with my BOB Yak trailer (single wheel)...best set-up is drop-out mount because it's lower on bike,tho wheel interference becomes an issue on tight turns...
chamunks says: Dec 28, 2010. 8:11 PM
Inspired and built. Though I swapped the main bar from steel conduit to aluminum pipe to lighten the load, and added some cotter pins in a few places to make everything quick release.
My U-Bolt didnt end up being too similar to yours and a slight mod or two to the actual coupling on my rig but all in all very good ible and this coupler works great I've hauled way more than I should have on this badboy for way longer than I should have.
I'm thinking though that whenever my sugru comes in the mail I will be padding the ring a bit so that my gunmetal black seat pole doesn't get too wrecked. I'll post some pics this spring when I can take them without freezing my fingers off if you're interested.
mr.incredible says: Aug 1, 2010. 8:07 PM
This might prove to be a stronger design along your same principles. Also there is less chance of the trailer separating. I just threw this together with Google Sketchup and parts from the 3D Warehouse.
frenzy (author) in reply to mr.incredibleAug 5, 2010. 7:09 AM
This is awesome but the hose bit needs to stick straight out to actually attach to the trailer.
mr.incredible in reply to frenzyAug 5, 2010. 6:19 PM
This would probably negate the whole "No Weld" theme you got here. I was also thinking the coupling on the tongue should be vertical.
mr.incredible in reply to mr.incredibleOct 29, 2010. 6:35 AM
thinking more about this...
I think uneven ground or hills might break or stress this one too much...
Dr.Bill in reply to mr.incredibleOct 17, 2010. 9:49 PM
Goose Neck Trailor hitch just like on PU Trucks with a 5th wheel.
I like this design mo bettah.
shmuki in reply to mr.incredibleAug 21, 2010. 9:44 PM
Would it be possible to get a 90 degree elbow for an air hose so that you could have the upright pin?
BillBiker in reply to mr.incredibleAug 2, 2010. 6:00 AM
On the curve of the u-shape that goes around the seat post one could take a hacksaw and put small cuts on the bolt to keep it from walking side to side maybe?
Mike Z says: Aug 4, 2010. 4:21 PM
Call me stupid -- (Your stupid!!!) But please show me how this attaches a trailer to the bike.
Big Bear says: Aug 1, 2010. 12:10 PM
The u-bolt plate looks thin and weak . You may get a more secure hold on the seat post with a thicker stronger plate. This is a nice idea though with some good thought.
l8nite says: Jul 31, 2010. 11:09 PM
very cool idea. nice ible although you could have shown the female part as well. Cutting off the excess threads would make it easier to manipulate the fittings, at least for those of use with larger hands
frenzy (author) in reply to l8niteAug 1, 2010. 8:54 AM
The female end is on the original trailer hitch instructable
l8nite in reply to frenzyAug 1, 2010. 9:22 AM
I know the female is shown on the other ible, all I was suggestioning was that showing it here would help tie your ibles together and show the finished piece
omnibot says: Jul 31, 2010. 5:00 PM
Excellent, this really solves this problem in a most handy fashion.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
