My garden beds are a combination of a few things I like.
1- would be raised bed gardening and in particular square foot gardening
2- Hugelkultur - this is a technique where wood is buried inside of the garden bed which greatly reduces and even can eliminate the need for irrigation. Don't take my word for it... read this, and listen to this and this For the purposes of this instruct-able I'll ask you to suspend your disbelief and lets just assume your on board with hugelkultur. If you want to debate it take it up with Paul or Jack.
Tools I used
Hammer
Pipe clamps (not 100% required)
Circular Saw
Miter Saw (can use circular saw for all cuts, but it makes it easier)
Drill
Tape Measure
Carpenter's Pencil or Sharpie
Level
Mattock (not required but suggested)
Shovel
Kreg Jig - I used the Jr. version
Socket Wrench
Materials
3" 5/26 galvanized lag bolts Quantity: 12
5/16 lock washers Quantity: 12
Ondura Corrugated Roofing Sheet ** Quantity: 2
Galvanized Roofing Nails Quantity: 50 to 100....
Pressure Treated 8' 2x4 lumber* Quantity: 9
2.5" Kreg Screws Quantity: 56
Note: I would suggest getting your bolts at a place that sells them by weight such as tractor supply. It will end up being a lot cheaper.
Cut List for 2x4s
8' (note does not require cut) Quantity: 4
4' Quantity: 4
17.5" Quantity: 14
* My research indicates that current, modern, pressure treated lumber is safe for use in the garden. Please do your own research and present facts rather than flames should you choose to comment on this material. A more expensive alternative would be cedar or redwood.
Please before you spout off about "arsenic" in the comments be aware that ACQ treated lumber does not contain this substance!
http://www.walterreeves.com/uploads/pdf/acqwood.pdf
**Ondura is light, easy to work with and cheap. However if you are uncomfortable with plastic in your garden you can use traditional metal roofing for this project
Step 1: Step: 1 - Cut all 2x4s to length
Cut List for 2x4s
4' Quantity: 4
17.5" Quantity: 14
Step 2: Drill your pocket holes
You will need 10 pocket holes (5 sets of 2) in each 8' board
You will need 4 pocket holes (2 sets of 2) in each 4' board
First mark your boards where the edges of your 17.5" supports will be with a pencil or sharpie. Refer to the photo for the approximate dimensions. You don't need CNC machine precision here. Just make the middle support centered and the other 2 supports should have a 10 3/4" gap from the edge.
The 10 3/4" gap is significant. The ondura sheets are shy of 8' long so one of these supports will cover your overlap and hide the seem. The one on the other side exists for symmetry in addition to support.
The Kreg Jr. Jig comes with an instruction manual which should be adequate, however watching this video should give you an idea of what is involved:
Step 3: Screw your panels together
If your 2x4s are bowed you can clamp them using some long clamps such as pipe clamps to hold them in position.
Drive your 2.5" kreg screws into the 17.5" supports.
You should now have finished panels ready to accept Ondura sheeting.
Please bear in mind that the side with the exposed pocket holes should face inward (so that the joints are hidden)
Step 4: Cut the ondura roofing
To do your cross-cuts you will have to readjust your blade height.
I would advise you to cut it outside on some saw horses. Adjust your circular saw to the minimum depth required. There is no need to make sure the cut is perfectly square as the edges are not going to be exposed in the final product. Just eyeball it.
Step 1:
Rip both sheets lengthwise at 24"
You should now have 4 approximately 7' long sheets of ondura.
You want to leave a minimum of 2.5" of exposure on the end of each panel. Refer to the second drawing
Step 2:
Measure your 4x3 panel 2.5" in from both sides. Cut 2 pieces to fit this width
Step 3:
Cut one of your scrap pieces in half. You will use one these to fill the gap on the end of each of your 8' sides.
Step 5: Nail roofing material to panels
Drive galvanized roofing nails liberally to secure the roofing material to the frames.
A finished 2x4 frame should look like the one in the first photo. I don't think it matters which side you face out. I chose to face the black side out, however ondura comes in a variety of colors and you might wish to face the color side out.
I had roofing nails left over from another project and used both the standard nails and the ones with the plastic caps. I found the plastic cap nails to conform nicely to the curves of the ondura. Overall I liked using those better than the standard ones.
The second photo illustrates a completed bed.. you can see the roofing nails in it. I tried to space them fairly evenly.
Step 6: Bolt together your panels into the final bed shape
Hold one side up to another. It helps to have a partner hold them together or in my case I used some quick clamps as an extra set of hands.
Pre-drill a lag screw hole in the top 2x4 and drive in a 3" lag screw with your socket wrench. Make sure the tops are flush before drilling!
Drill a second hole in the middle (eyeball it) and drive a 3" lag screw there
Finally drill a hole in the bottom and drive a 3" lag screw there
You will be using a total of 12 3" lag screws to bolt all 4 frames together. There should be 6 bolts on each side
The photo shows what it should look like
These are pretty heavy, so assemble this as close to where it will go as possible.
Step 7: Level the bed
Take your level and place it on the bed. Dig a trench with a mattock and scoop it out with a shovel around all sides until you have made the bed level. You can dump the removed soil into the middle of the bed. I chose to reserve the soil and dump it on top of the logs after I did step 8.
The photo shows 2 leveled beds
You can see the trench required. These were placed on a slight slope and one end needed to be dropped about 5"
Step 8: Fill with wood
I first layered the bottom with the largest logs, second I placed much smaller branches all around.
If you have leaves you can put down a thick layer of leaves here. You can also scoop in any excess dirt from leveling the beds on top at this point if it was left around the edges.
If you want an even greater effect you can dig out the bottom of the bed to make room for more wood, that's up to you and how ambitious you want to get.
The photo shows my beds awaiting soil.
Step 9: Fill beds with compost
We found that 1 pickup truck full (2 "scoops") fills up one bed.
We used a combination of organic cow manure and organic mushroom compost.
In the very top layer I mixed in peat moss and vermiculite to make my "mel's mix"
The attached photo shows the bed before I added the vermiculite and peat
Step 10: Square foot gardening grid
Here are some links to some free square foot gardening planning tools:
Gardener's Supply
Smart Gardener
In his book "All new square foot gardening" Mel suggests only using rigid grids. I find rigid grids harder to work with and more expensive to install. I prefer a simple Nylon clothes line available at any home center. I even got a glow in the dark clothes line from Harbor Freight.
Cut a scrap piece of wood to 12" long
- Using the wood as a spacer add a galvanized nail every 12". I chose to drive my nails into the side of the bed rather than the top. This is so I can leave the top flat in case I want to add a green house to the top or otherwise utilize that surface area.
- Tie the clothes line to a nail and simply start wrapping it around to form the grid. I started in the short dimension first for no particular reason.
- When you get to the point where you need to change direction you will need to drive an extra nail in that corner.
It is really very simple, however please refer to the photos for clarifications.
To come:
1 - removable deer protection panels
2 - pvc trellis
4- cucumber trellis
5 - pvc tomato grid
Visit Our Store »
Go Pro Today »
https://plus.google.com/u/0/photos/116799145749804483138/albums/5739443476146341281
USDA certified organic producers are not allowed to use pressure treated wood of any kind in their production beds.
CCA pressure treated wood has been injected or soaked with chromate copper arsenate, or chromium, copper and ARSENIC
I would advise everyone thinking of using in their garden to do their own research as to wether it is appropriate in their garden.
Rough cut hard wood works just as well and doesn't need to be kiln dried to use. You will not find it in a big box store but maybe a ride into the county would be a nice relaxing experience.
Even with CCA treated lumber the studies and soil samples taken from the soil have shown nothing above normal levels of arsenic after the first 2 inches of soil past the wood.
Again this is not relative to my project because I am using ACQ
Do your homework. Newly purchased pressure treated wood is ACQ
Your information became outdated around 2004 when supplies stopped producing CCA treated lumber.
-Nick
As far as compost goes I generally add it at the beginning of the year. I have 3 large piles where every 3rd year one is ready to go into the garden.
Hope that helps
-Nick
http://www.instructables.com/id/Raised-Beds/
I find ondura too flexable. I use it on my shed roof and on top of one of my waterbutts. The cat sits on the ondura and it bends under her weight and she's a pretty small cat (with a fat bum). The wood I'm guessing will reduce the weight and the ondura will repel water into the bed which is good.
I wouldn't be happy knowing that the ondura (or my native similar stuff is, not sure about ondura) is made from oil and cardboard - I'd be worried about chemicals leaching into the soil.
Good instructable though - congrats on your first making front page!
It's better than the salad I'm probably going to eat for lunch at the restaurant next to my work, which was sprayed from start to finish with toxic chemicals and raised with petroleum fertilizer. People hold the home gardener to unreasonably high standards. It's funny how high the standards go once you have unlimited access to analyze the methods of production.
I'm not saying your wrong, you have to do what is comfortable for them. I'd suggest using traditional metal corrugated roofing for this project if you don't like plastic in the garden.
More $$ but may relieve some concerns. With or without the Hugekultur, it's a very well thought out plan. Thank you.
http://www.puyallup.wsu.edu/~Linda%20Chalker-Scott/Horticultural%20Myths_files/Myths/CCA%20wood.pdf
http://pubs.cas.psu.edu/freepubs/pdfs/uc173.pdf
While I appreciate your concern regarding treated wood and gardens, the references you cite are a bit dated. CCA pressure treated lumber was banned for consumer use by the EPA in 2003. Any pressure treated lumber manufactured for consumer use after that date has no arsenic in it.
They aren't typically a problem in my area. My wood is buried under a foot or so of soil, not sure if that is a deterrent or not.
I am off to a local supplier for vermiculite, compost and peat moss tomorrow to mix up Mel's Mix and hopefully finish these off tomorrow and get them planted by the weekend.
A couple of suggestions on the build. I used the lag screws as you had mentioned but found that the cedar was too soft to hold very good after pre drilling and some of them stripped out. I reinforced the connections with 3" deck screws and should of used them by themselves. I also used them in place of the Kreg screws, one because the cedar is nominally thicker than than the treated lumber and two they are much stouter and better designed for outdoor use. The Ondura, if you want to have the color side facing out, you need to bend the ridge down because after you cut the panels in half the cut edges are "up". This is easily accomplished especially if you let them sit in the sun for while, but it doubles the use of the roofing nails to give the panels a clean edge on the top side. Overall an EXCELLENT Instructable, very well laid out and a wealth of information. Thanks again.
The wood has to soak up a ton of water and also start to break down, which will draw nitrogen from the soil.
So in the first year you have to water and also will have to watch to see if they need fertilizer.
After filling them up water the "hell" out of the beds to get them nice and soaked.
After year 1 when the rotting process starts taking hold you will start to get the benefits and also as the wood breaks down it will release nitrogen back into the soil and feed your plants.
Cheers!
-Nick
Also your measurements don't need to have surgical precision. As long as you have surface area to nail the stuff to you are good. In fact I had more problems with them being a bit too short, and this the ondura hanging over a bit then the opposite
At the end of the day do this. Cut a sheet in half. Lay it on a 2x4. Where it ends make mark. Put your brace there so u can nail the ondura on it. Overlap your scrap piece and nail that in to make the 8'
Make your other brace the same distance in so it has symmetry for looks. Put the 3rd brace in the middle so it also looks nice
Anyway just use my dimensions and you will be fine
I'm not asking for costs on tools or what goes inside the beds once they are built. I'm also aware that many people viewing Instructables are not in the US, so these costs may not apply to everyone. Thanks.
http://bit.ly/H8tdh5
I believe it is illegal to sell the old bad pressure treat in the US. Current wood uses copper or borates. On land they should be fine, but water runoff to a pond could still be a problem. It is a good idea to wear a dust mask even when cutting the new boards. Common concentrations available at a lumber yard are usually meant for above ground applications. You will have to pay extra for higher retention levels suitable for ground contact or ground burial.
I knew people would flip out about the materials when I posted it. All I can do is roll my eyes and say "Make your own flipping decisions for your life!"
LOL
The 99% are incapable of that nowadays.
It's all about do it for me, including learning the actual benefits/drawbacks of any given item.
Think for yourselves people.
Personally I'm fine with whatever trace chemicals might make their way into my garden via the materials I am using. I feel my food will be at a far higher standard, from both a taste and nutrition standpoint than what is commercially available. I've design a system which I feel will be long lasting and low maintenance.
So far I'm very pleased with working at the higher level (2') It's great to be able to stand while gardening. That might just be worth it all by itself.
The whole zen behind the French Intensive method is to have loose soil, and water below, so roots are encouraged to grow down, not out. The neat thing about this, is you can plant things much closer together, such as a root crop, like carrots or potatoes, in between the tomato plants or beans. Planting things this close together will reduce weeds considerably- and even if you do have to weed, you are not on your hands and knees or bending way over. I have made my previous beds no more than 2 arm lengths wide- for easier weeding.
As far as the bed preperation method you describe goes. I don't see any reason why you can do exactly what you have described except make your first layer logs for hugelkultur.
View the video series i have linked up. You will see Jack from TSP dig a very deep pit and fill it with logs. Pretty much the inverse of I have done w/o heavy equipment
There are pros and cons for going up. On one hand it's a real back saver and I think day to day maintenance is better, on the other hand you need a ladder to harvest your pole beans
Eliminating the need to water your garden is both a time and resource saver as well as maximizing the root growth aspect you have mentioned.
Also with French intensive I imagine you have to recharge it every year, where a hugel bed you only would recharge maybe every 5 to 10 years
Pretty much just add compost to bring it back to level every year... I'd also suggest sheet mulching your garden too... will retain even more moisture and also build soil... how cool!
If you don't mind eating food contaminated with bug killer and plant killer, use treated wood. The contamination comes from leeching after every rain. The old stuff was proven to leech, and since only the chemical was changed expect leeching to happen into the soil.
As far as the ondura leeching, It is the same materials your roofs shingles are made of, so if there is harmful leeching, its more than likely too late. But since oil products naturally take care of any contamination (see the BP spill), and grass and gardens grow just fine in old auto junk yards, its probably the last thing i'd worry about in a box like this.
I my self obtained damaged poly floats for docks, cut the tops open leaving a 6" seat around the top edge. I put a clear tube outside to indicate water level, and use a drip system for watering and fertilizing. The water used is collected rain water. These floats can be had in a variety of sizes from 18"x30" to 4'x8' and from 1' to 3' deep. Usually from the manufacturers or dock dealers.
I'm also doing a "larry hall" gutter garden (google it) which will feed from some rain barrels off a, wait for it, asphalt shingle roof :D
Thanks again for the comments.
