No irrigation raised bed gardening system (Hugelkultur)
 by SaveOurSkills
Featured
Step 5: Nail roofing material to panels
On a flat surface face your pocket holes up. Lay your roofing material down on the frames. If your edges overhang make sure that they only overhang on one side. This can be the side that rests in the soil. You do not want exposed roofing edges.
Drive galvanized roofing nails liberally to secure the roofing material to the frames.
A finished 2x4 frame should look like the one in the first photo. I don't think it matters which side you face out. I chose to face the black side out, however ondura comes in a variety of colors and you might wish to face the color side out.
I had roofing nails left over from another project and used both the standard nails and the ones with the plastic caps. I found the plastic cap nails to conform nicely to the curves of the ondura. Overall I liked using those better than the standard ones.
The second photo illustrates a completed bed.. you can see the roofing nails in it. I tried to space them fairly evenly.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
