Introduction: No Tool, Adjustable, Bike Helmet Light.
Fed up groping around in the dark when getting my bike out of or putting it back into the shed I decided I needed a helmet mounted torch. The commercially available ones all seem overcomplicated and/or poorly secured to the helmet. Messing about futilely attempting to secure one of my existing head torches to my helmet using the supplied band it occurred to me that all I needed was a single zip tie.
The key lay in the back plate of one of my head torches, which happened to have several hooks and loops that you could pass a zip tie through.
Step 1: Materials Needed
1. A helmet
2. One or more Zip ties
3. A head torch with the right kind of back plate*
*My petzl was not suitable, what worked was a head torch I picked up in the local supermarket. They no longer stock them but when I wanted to make a helmet torch for my wife I found numerous cheap lights online which use exactly the same moulding for the back plate. In the end I got one like that pictured above from ebay for under £2 including postage if you search "head torch watt" you should find something similar.
Step 2: Fixing the Light to the Helmet
First remove the elasticated band which came with the torch, then zip tie the torch to the helmet.
On my helmet this could hardly have been easier all it took was a single zip tie.Due to the design of my wife's helmet it was a little more complicated but still far from difficult.
You'll just have to see what works with your helmet.
Whilst I was at it I thought I'd also fit a rear light, in each case this was incredibly easy requiring only a single zip tie, most rear lights I've seen would be suitable.
Step 3: Job Done
We've been riding regularly with these lights for several years now with no problems. I don't notice any extra weight on the helmet both because the lights weigh very little and possibly because the front and rear lights balance each other so the helmet doesn't tip forwards as I suppose it might with only a front light.
The lights make locking and unlocking the bike in our shed much easier and importantly also make us more visible to drivers, particularly at junctions where your handlebar mounted lights can be obscured by cars waiting next to you.
Bikes and Wheels Contest
Great Outdoors Contest
