Firewood rack using no tools
 by clasof56
Featured
Building a no-tools-needed firewood rack
A good, stable, easily-movable, cheap firewood rack is a thought-provoking project.  This is what i have used for years and it works extremely well.
It holds a face-cord of heavy, wet wood with no problem.
This is what you need:
     2 or 3 concrete blocks
     2 landscape timbers
     2 2x4s  - 8 or 10 footers cut in half...pressure treated.
total material cost about 15 bucks
I think the pics say it all but some tips:
  - place 2 concrete blocks holes up on a stable surface,  3 if support needed in center (not often).
  - place timbers across outside edges of blocks
  - place 2x4 pieces in holes in blocks.  If on dirt put a few
    rocks in holes first to drain water from 2x4' ends.
  - its designed so the 2x4's are leaning out at the top. is
    very strong like this. the last pic shows my new double rack. one  more block but 4 less 2x4 pieces and stronger because of center blocks. if you enlarge the last pic, you can really see how much weight this set-up will hold. and i could put a lot more on it but its over my head..hahah
I cut a piece of plastic tarp about 4' wide and 10' long to cover wood... i take a couple of holed bricks and tie lite 3' rope from one to the other and lay over tarped ends to keep tarp on in wind.  all of this works really well together. rack gets stronger with more wood and is very stable. everything comes apart to move to another spot or put in storage (or use for other projects). Rack is high enough off ground to blow leaves from underneath or spray for bugs. Its nice to be able to easily move a woodrack as sometimes the ground under it becomes unstable and the rack will lean.  Or sometimes you just find a better place and moving individual pieces is so much easier than moving the whole rack at once.
CarlTheDabbler says: Apr 13, 2013. 11:53 AM
Excellent idea. That's a simple, elegant, cheap solution. I'll be giving this a try!
grillmaster says: Nov 1, 2012. 2:01 PM
Took about an hour to make 2 racks. Had the 2x4's, only had to spend $10 for the cement blocks. Worked like a charm and yes, as the wood gets piled on, the rack actually becomes more rigid.... my friend came over and he was totally impressed, thanks again.
clasof56 (author) in reply to grillmasterNov 1, 2012. 2:12 PM
ah, glad you found it helpful...never need another kind.
grillmaster says: Oct 31, 2012. 11:26 AM
Gotta love the KISS method. I've never seen anything so simple, congrats for the idea and thanks for sharing.
Farmer-Al says: Oct 5, 2012. 7:19 AM
Genius!
areyouolsen says: Sep 30, 2012. 9:42 AM
Awesome. Thanks a lot! Just got done stacking a couple of cords of wood, having made two in the span of about half an hour. The perfect solution - simple & effective.
Many thanks!
vjdoro says: Mar 3, 2012. 3:15 PM
Thank you for this simple but very effective firewood rack.
Svenska in reply to vjdoroSep 11, 2012. 3:25 PM
Brilliant, I had all the materials on hand. My 4x4's were salvage from Home Depot, so only 4' long. Added a cinder block in middle for support & worked great. Wish I had thought of it myself.
Jeanette56 says: Aug 15, 2012. 9:21 PM
Brilliant! I am so glad to have found this! I've pinned it on Pinterest so I can find it again this weekend (and so others can see it too!).
clasof56 (author) in reply to Jeanette56Aug 16, 2012. 4:37 AM
hi jeanette, thanks for the nice words. hope you get some use out of it sometime. i hadnt heard of pinterest and took a look. send me the link if you pin this, just put it here...thanks.
Jeanette56 in reply to clasof56Aug 16, 2012. 4:56 PM
Here is the link to one of my Pinterest pages that has your tutorial link on it.
http://pinterest.com/jeanette5674/my-stuff/
Thanks again!
pcos_us says: Jun 18, 2012. 8:10 PM
Just built 2 in Michigan for around $20 each including a block in the center. Used 5' tall 2X4 cut on angle. First set used two course blocks for more elivation. Very sturdy and fast to build. Nothing better for sale on the web. Thanks
clasof56 (author) in reply to pcos_usJun 22, 2012. 4:38 AM
hi pcos, glad you are having success. one thing you might try. with three blocks, try putting one 2x4 in the center block. that will allow you to separate two different loads of wood so all the drier stuff doesnt end up at the bottom of the full stack, or you can have larger stuff on one side and smaller on the other. i am from michigan and enjoyed many a fireplace there...cheers!
northcalgreens says: May 22, 2012. 5:11 AM
Perfect example of K I S S
Nessesity being the mother of invention,couldnt have done much better.
Great ible!
clasof56 (author) in reply to northcalgreensMay 22, 2012. 3:25 PM
thanks guy, i got 7 of them going now...all stong and stable
northcalgreens says: May 22, 2012. 5:08 AM
nordbach says: Mar 23, 2012. 5:12 AM
A firewood rack with a high WAF (WifeAcceptanceFactor). You don`t see that very often ;)
clasof56 (author) in reply to nordbachMar 23, 2012. 6:55 AM
hahah...good comment...much better a WAF than a WTF, eh!
ALEX_HOLAND says: Mar 15, 2012. 3:47 PM
Like a Sir.
My complements.
bodie says: Mar 12, 2012. 7:18 AM
I read your 'ible on Friday and on Saturday my wife asked me to move our woodpile. Great timing! I happened to have some cinder blocks laying around, so I tried it. It worked like a champ!
clasof56 (author) in reply to bodieMar 12, 2012. 8:15 AM
hahahh....isnt it great when a plan comes together!!
i got a kick out of your comment and thanks for posting it. sometimes simple works pretty good.
Rebellemming says: Mar 9, 2012. 3:57 AM
Fabulous idea that really is both helpful and a thrifty use of resources. Thanks
ilpug says: Mar 3, 2012. 6:51 PM
I noticed that your stack is kin of pushing outwards. It helps if you get rope or baling wires and rung a few lines in between either end of the stack structure. It lends a lot of strength and you simply stack on and around the wires.
clasof56 (author) in reply to ilpugMar 4, 2012. 5:17 AM
hi illpug, thanks for the comment. i have tried stringing wire before while trying different stacks. but this setup is actually designed to be out further at the top. and its very strong. i am in florida and love to have a fireplace and in a normal year have about 100 and i go thru about 6 cords a year and have the stacks all like this. have never had one fall or fail. sometimes a landscape timber bows a bit but then the next year i just turn that one over...hahah
paganwonder says: Mar 3, 2012. 4:34 PM
VERY clever...cheap as well...definite WIN!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
