NodeMCU / ESP8266 Cap Rail Mount
850
15
Posted in TechnologyElectronics
Introduction: NodeMCU / ESP8266 Cap Rail Mount
I want to show you in this instructable - how to mount a NodeMCU V2 (ESP8266) module in a cabinet. This can be very useful for many professional applications like door access systems, smarthomes etc. There are many different ESP8266 modules on the market. The programming is nearly the same for all, but the pinout is different. We have create a special enclosure set for the NodeMCU V2 Amica.
On the following pages you will find a detailed description about the assembly of the NodeMCU Amica and our cap rail enclosure kit for cabinet mount.
Please visit also our project website for detailed information.
Step 1: Tools & Materials
Materials:
Tools:
  • soldering iron with small tip
  • side cutting pliersneedle nose pliers
  • medium cross slot screw driver
Step 2: Prepare the Terminal Blocks
Find the terminal blocks, they're grey or blue and come in 2-pin and 3-pin shapes. We'll need to slide two 3-pin blocks together.
Step 3: Place and Solder Terminal Blocks
We've to put the blocks into the proto plate. Make sure you place them so that the openends are facing out as shown
Step 4: Place and Solder the Diode
bend the pins of the diode D2. Place the diode onto the pcb and solder the pins.
Step 5: Prepare the Female Headers
Depending from the situation on the market we sell the kits with longer female header. You have to cut these headers to 15 pins
Step 6: Prepare the NodeMCU
Plug both female headers onto the male headers of the NodeMCU module
Step 7: Place and Solder the NodeMCU
Step 8: Remove the NodeMCU Module
Step 9: Solder the Jumper J1
beside the blue terminal block is a soldering jumper. You have to solder a bridge on this jumper if you want to connect later a external 5V power supply
Step 10: Mount the Pcb Into the Bottom Shell
Step 11: Mount the 2 Holders for the Din Rail
Please take care to mount the holder from the inner channel to the outside!
Step 12: Mount the NodeMCU Again and the Top Shell
Step 13: Internal Voltage Regulator
It's possible to extend the basic kit with a voltage regulator (input voltage 9...35V; output voltage 5V)
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
