NodeMCU Onboard LED Access Via Web Server
Published
Introduction: NodeMCU Onboard LED Access Via Web Server
About: The eternal noob DIYer is something I would call myself. Understanding everything in the most layman terms and trying to explain the same to others is my job.
The ESP8266 is THE device in the DIY market. It has brought a nice big storm in the Hobbyist community. Coupled with GPIOs , an ADC , SPI interface, UART interface (and of course the WiFi part)...it has all the features required to make a full blown standalone application without any extra piece of hardware .
Step 1: Some Basics on Programming the THING
Programming this brilliant THING is generally done by
  • Arduino IDE (C++ implementation)
  • ESPlorer IDE (LUA programming language)
This tutorial is about controlling the LED present on the ESP Development board using the ESPlorer IDE.
Step 2: Setting Up the Firmware and Tools
For the NodeMCU to understand our LUA program , a firmware needs to be flashed on it first before uploading the actual LUA code. So the following steps need to be followed.
  1. Download the binary files (firmware needed onboard the esp12e) from here
  2. You will need some tool to flash the binary (firmware). You could either use esptool or nodemcu-flasher (only windows).For the esptool , unzip it, run "python setup.py install" inside extracted folder,and finally
    "sudo python esptool.py --port /dev/ttyUSB0 write_flash 0x00000 your_downloaded_binary_in_first_step"
  3. The "/dev/ttyUSB0" is the port on which the device is connected. Check here and here for more info on esptool. For the nodemcu-flasher follow the instructions on wiki
  4. Download the ESPlorer IDE for flashing our LUA program here (Hit download button on the page).
Note - Make sure NodeMCU is connected to the PC by checking inside device manager (for windows,you will find your device under Ports as "Silabs CP201x...." )
Step 3: Programming the NodeMCU
Well most of it is done.All you need is the LUA code to turn your ESP12E into a web AP as well as Web server. Here you will find the code. Just copy the code in the left Window of your ESPlorer IDE and save as "init.lua" (this is the first script that runs on the NodeMCU after reset).The ESPlorer automatically saves the code on your NodeMCU code memory.
Once all is done , search for WiFi networks on your device (phone or PC). You will find something like this "ESP8266_" .
  • Connect to this WiFi network with password as "12345678" (without quotes).
  • Fire up a web browser and write the following in the URL bar "192.168.4.1".
  • You will find "on","off" and "blink" button . So....off you go.
Step 4: A Look Into the Code
You can get a better understanding at NodeMCU-docs and here.
The code flow is as follows
  • The init.lua code first configures the ESP modules into a WiFi access point.
cfg={}
cfg.ssid = "ESP8266_"..ssidTemp
...more code upto...
wifi.setmode(wifi.SOFTAP)
  • GPIO button 0 is configured as OUTPUT
gpio.mode(led1,gpio.OUTPUT)
  • A Server is created and the status of the buttons on the HTML page are checked each time the status of either changes
srv:listen(80,function(conn)
..more code upto...
end)
So that is a basic html page to control on board LED using LUA code. Happy Hacking!!
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
