Every HDD makes some noise...Fact
But! This noise is in fact amplified as HDD touches the metal case of our PC.
So if between our case and the HDD is something else (see rubber strap from a tire inner tube) then the noise is deduced significantly!
Remove these ads by
Signing UpStep 1Materials Needed
Cross cuts from a tire's inner tube (or anything like a rubber strap)
and some screws.
Use these...
The HDD makes up a small amount of noise so this isn't really effective unless your pc has no fans because its low power or your pc is water cooled.
Actually, HD is a bit confusing now. The new version differentiates between a HDD (Hard Disk Drive) and SSD (Solid State Drive).
You decided to nitpick ONE thing in the entire article, then make a snarky comment about using the 'classic' term HDD. There was absolutely no reason to be that snarky. None.
I, for one, laughed at the rhetoric and irony of how you got to this post :p
