You can get the kit from Gadget Gangster & grab the schematic. here. The kit comes pre-programmed. But, if you'd like to gather the parts yourself, you'll need the following.
Parts list
- Resistors, 1 each of : 1k, 3.3k, 330, 560, 100k, 2.2k, 220k
- 4 x 10k Resistors
- Gadget Gangster project board (half board)
- 10 uF Cap
- 8 Pin Dip Socket
- 3xAA battery holder (and batteries)
- 10k Photoresistor
- Micro Speaker
- 22Ga Hookup wire
- And a programmed PICaxe 08M. You can get the Source Code off Gadget Gangster
Here's a little video demonstration
How to Play It
The NoiseAxe will play 8 different notes, each note is played by touching one of the 8 resistor legs at the bottom right of the PCB with the stylus wire. You can change the level of modulation by varying the light that enters the photoresistor, creating a vibrato effect. This is done by putting your finger over, or shining a small LED torch onto, the photoresistor.How it Works
The NoiseAxe is based around the Picaxe 08M micro-controller. The 8 different notes that it will play are controlled via a stylus that you use to touch each of the 8 resistors legs at the bottom right of the PCB. Each resistor makes a voltage divider that produces a different voltage when that resistor is touched. The voltage is sensed by the ADC (analog to digital converter) on the Picaxe and converted into one of 8 values in the program. The 8 note output corresponds to one octave on a keyboard. The sound command is then used to output the correct note to the speaker. The photoresistor is also used in a voltage divider circuit connected to one of the inputs the micro-controllers ADC. A digital value is read within the program and added or subtracted from the frequency sent to the sound command.Step 1: IC Socket
Step 2: Wire Links
-E2 to Q2
-L4 to Q4
-A4 to F4
-D6 to F6
-D10 to E10
Step 3: Resistors
- R1; A12 to L12 330R
- R2; A13 to L13 560R
- R3; A14 to L14 1K
- R4; A15 to L15 2.2K
- R5; A16 to L16 3.3K
- R6; A17 to L17 10K
- R7; A18 to L18 100K
- R8; A19 to L19 220K
- R9; L6 to Q6 10K
- R10; E5 to F5 10K
- R11; C6 to C10 10K
Step 4: Capacitor
Step 5: Photoresistor
Step 6: Stylus wire
Step 7: Battery Box
Solder the Black wire to E1 on the top side of the PCB.
Step 8: Speaker
Bend the wires to place the speaker in the place were you want it.
Step 10: Fit Batteries and Test
That's it! To grab the schematic, source code or to order a kit, check out the project on Gadget Gangster.
Visit Our Store »
Go Pro Today »
I need a continuious sourse of power when the quilt is being exhibited. I am not an electronic person. I need help.
I would like to have a sourse of power that is very light and it can be sewn on the back of the quilt and be a power source to eluminate the conductive threads. With an on and off switch. If these power sources could be light enough so that more then one can be incorporate , because the quilts are very large. If you have any ideas I would be gratefull.
Thank you for your time and energy. Maria E. Cosimano-Kohl
