Nokia C2-01 phone LCD screen replacement
 by Libahunt
If you happen to have a Nokia C2-01 mobile with cracked screen and you decide to replace the LCD yourself, then here are some pictures and descriptions of what to expect from the dismantling process. I'm not any kind of expert in mobile repairs, I just succeeded somehow and documented the process.
Things you'll need:
  • replacement screen
  • small torx screwdriver - T6 probably
  • something for prying things open
Screen: I got mine through e-bay from Hong Kong. It's probably cheapest. The colours on the screen in my opinion differ from original, but who cares, it's just a phone. And very conveniently it had the two mentioned tools in the kit. There are probably other places to source the screen from, find one according to your location, preference and budget.
Torx (star) screwdriver: I measured the point-to-point size with caliper and it was 1.7mm which should be T6 according to wikipedia. But if you are going shopping for it then take the phone with you. Under the back part, just where battery is, there are two screws to compare the driver to. Other four screws you need to open later are the same.
Prying tool - preferrably should be made of plastic. Something with thin edge. Or if you can't find anything plastic then metal with smooth edge (not a sharp knife).
Warning: mobile phone as any kind on electronic device can be damaged by static electricity while the protective casing is removed. Wear natural material clothing, don't work on a carpet and try not to touch the components on PCB or the screen connector metal tabs side... and all the things you might know yourself that help prevent static electricity damage.
Here's an anectotal story, why I got to replace the screen in the first place.
I was riding my bicycle in the center of my hometown, it was slightly rainy. I went to a shop and found that my phone is nowhere with me. Last time I had seen it was when I looked up the time while riding and put it back to a pocket of my pants. I asked the shop staff to call my number and it gave ringing tone - so it was not in the hands of mean people who would have removed the sim-card to avoid tracking. So I went back the way I had came and passed all the areas where I was riding on the car lane far from pedestrians. So I thought if it is not here, then someone has picked it up already because rest of my journey went through very busy area, pedestrians everywhere, no way the phone would lay there long. But I kept going the same way and I found my phone! It was in the middle of a small street crossing to bigger one. The imaginable crossway was ten meters into the street so no pedestrians had seen the dark coloured pieces. And no car had driven over it either - it was so small street. Fourty minutes had passed since I looked up the time from the phone right about in the same place. And the thing seemed to still work.
But ... as it was rainy day, when I got home I decided to dry the phone properly and started to pry open the front part of plastic. I completely ignored the possibility of presence of screws. The screws in this phone are in the middle of longer edges. If they would have been in corners I would have seen them and acted logical, but as both ends opened a bit on prying I wasn't even thinking about screws. But the two screws existed despite my ignorance and prying ended with cracked screen.
Anyway it all ended much better than usual losing a phone scenario. I got to post an 'ible :)
Step 1: Dismantling 1
  1. Remove the backside cover. It comes off if you slide it downwards.
  2. Remove battery.
  3. There are two screws each in the middle of a longer side. Unscrew them.
  4. Pry open the front side cover and put it aside.
lowens1 says: Jan 25, 2013. 7:26 AM
rad, thank you. worked a treat.
Libahunt (author) in reply to lowens1Jan 25, 2013. 9:39 AM
You're welcome :)
Glad to hear that it was useful.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
