3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Non-PV Solar Power
Step 3Attach things
Attach things
Now you will want to firmly attach your peltier to your heat sink. I used iron wire to hold it on and keep it from sliding as you can see, but really, any thin material that can resist the high temperatures and you can wrap around will work fine. Gluing or taping is not recommended because it will not stick to the smooth heat sink surface.
After this you should attach the fan. What I did is like I did with the "baseplate" as you can see in the next step. I put rubber bands on the base of the fan and around to keep it on. I had to put a bit of cardboard between the base and the heatsink fins to keep the fan blades from hitting the sides of the heatsink. I bent the cardboard so part of it would slide into the fins and this worked perfectly, almost holding the fan in on it's own!
1 comment
Oct 10, 2009. 8:07 PMbadapuss says:
 What about using thermally conductive epoxy?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:bananafred
