I know how you feel, you want to be able to breath fire, but you are not too keen on putting poisonous chemicals in your mouth. In this Instructable, I'll show you how to blow a 10-foot-high plume of fire out of your mouth. Obviously any activity that involves large quantities of fire has some risk, but this method of firebreathing uses foods as fuel, so there is no danger of poisoning from ingestion of the fuel. Also the fuel is not flamable unless it is aerosolized. This means that if you spill on yourself, your shirt is probably no more likely to catch fire than it was before. With that said, I take no responsibility for your safety.
The companion video provides instuctions and a demonstration.
Remove these ads by
Signing UpStep 1Materials
Fuels intended for human consumption that I have tried with good results are:
Corn starch
Non-dairy coffee creamer - powdered
Powdered sugar
I like corn starch the best. It has little flavor and produces a flame that burns very quickly with a satifying ripping sound
The most important thing to think about with your flame source is finding something that will not blow out too easily. In the video I used a cotton ball that I soaked in white gas camp fuel and then attached to a wire. Gasoline or alcohol should also work in place of white gas, as will many other things.
This will not work if you mix the cornstarch with water. The idea is to mix the powder with lots of oxygen. If the powder is wet, it will not mix well with oxygen. Mixing it with potasium nitrate might be an interesting execise, but that would definitely expand the explosion and burn danger.
You can check my youtube chanel for a new video using a potato launcher to blow the powder instead of your mouth. It is called "Flour Explosions."
You should always inhale and exhale through your nose until all fuel is cleared from your mouth, and train yourself to always pause for 1-2 seconds after a firebreath before inhaling. This helps reduce inhaling the dispersed fuel directly in front of your face.
Fire breathing with any fuel also poses the same risks of wind shifts, blowback, coughing, sneezing, hiccups and the involuntary 'gasp' reflex if something goes wrong, which all can cause fuel aspiration. So it should not be entered into lightly. Solid fuels do have the advantage of not wicking into fabric and making them flammable.
I'm not trying to be a buzzkill or anything, just pointing out important safety stuff that most people don't realize. Nasty firebreathing accidents, however, are a real buzzkill. I've been firebreathing for three years and training with some fantastic fire performers, and luckily the worst accidents I've seen have only been a few burnt noses and lips, and a few beard fires. I'd hate to see anybody injured firebreathing.
I was actually reading the ingredients of the coffee creamer I used in the video, and it turns out the first ingredient is sugar.
Flour will also work.
-M
