3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
NonTraditional Speedometer for Used / Homebuilt Car
http://www.walmart.com/catalog/product.do?product_id=4661205
Ever buy a used car and the speedometer died or wasn't working but you realy wanted that particular car?
Here is one method to make it driveable and be safe doing so.
For the cost of only $20.00 one can buy one of these Radar Guns , disassemble it and Route the reader facing down towards the ground ( In a location that is not prone to getting grimed up) and connect the readout on the dash. Accurancy wise they are same (if not better ) in MPH. Another benifit is that it tells true Vehicle speed and not transmission speed.
I will add later the more illustrated procedure of doing so.
1. Wired method of data transfer from sensor to readout
a. "Quickie version" for the "damn thing just died" times.
b. "Clean version" for Homebuilt / Full time useage.
2. RF method of data transfer from sensor to readout.
a. "Mount and Go" for the habitual used car buyer ;)
b. "Remote Mounted" for use with independant monitoring
(example: Your own vehicle "black box")
NOTE: For those concerned with accuracy and this type of speed sensing method, this type of measurement method is used for both company road tests as well as there are industrial models used for speedometer readings for agricultural equipment.
ADDED: If you desire a more Robust version for this application
For about $86 USD you can get a Radar Gun made be "Bushnell" on Amazon.com
http://www.amazon.com/Bushnell-10-1911-Velocity-Speed-Gun/dp/B0002X7V1Q/sr=8-2/qid=1163532760/ref=sr_1_2/102-5491525-8540103?ie=UTF8&s=electronics
The Bushnell one is what I used originaly for this project. Mainly because at the time it was on sale for $75 as well as the "toy" one was not on the market to test with.
17 comments
Jul 4, 2011. 10:00 AMrfeldersnatch says:
When my speedo quit I learnt the engine rpms for a certain speed in whatever gear. Rpms will vary up and down hills but you get a rough idea how fast your going and that's really all you need. I never got pulled over with out it and it wasn't due to conservative driving if you know what I'm saying
Dec 4, 2006. 10:35 PMKactapuss says:
seems like it would be easier just to fix the faactory speedo
Nov 11, 2010. 10:31 AMskylane says:
But not nearly as much fun or creative...
Sep 17, 2007. 9:31 PMstatic says:
Personally if a vehicle I had to have, had a non functioning speedo, I'd repair it if possible/ affordable or install an after market speedo. That way you would still have an odometer.
Nov 16, 2006. 8:23 PMBUKeithw says:
Hey guys, I'm not sure if directly pointing the radar detector at the ground would work, but I know it works if placed on an angle. I work for a county mosquito control dept. and we use radar units mounted on the rear of our trucks to monitor our speed and automatically vary the pesticide output... but in short, yea, it will work, theoretically, it can be done.. not sure if this fisher price unit would be too accurate, or last very long mounted under a car.. but still...
Nov 14, 2006. 8:13 PMAustinisi says:
kind of off topic, but this reminded me of one of my favorite things to do. hold a blowdryer out at passing cars and see if they visibly slow down!
Nov 14, 2006. 4:52 PMthematthatter says:
i saw a hotwheels one in Target, my friends wanted to mount one on a front of a car and watch how many cars with radars slowed down
Nov 14, 2006. 12:06 PMtrebuchet03 says:
"NOTE: For those concerned with accuracy and this type of speed sensing method, this type of measurement method is used for both company road tests as well as there are industrial models" I'll have to find the forum -- but they determined the calibration was pretty off from the factory. Not to mention range was poor. I'll dig it up later if someone doesn't find it first (I'm not on my home computer at the moment) ;)
Nov 14, 2006. 12:18 PMtrebuchet03 says:
http://www.austech.info/showthread.php?t=135840&page=1
I remember seeing it on the Make: Blog -- that's not the exact forum I was talking about, but there's more information there ;)
Wait a second -- you said point it down at the ground.... Did you even try this? <-- pretty sure that's not going to work - just based on the physics behind this ;)
Nov 14, 2006. 3:56 PMtrialex says:
OK I've never had the opportunity of playing around with one of these, but surely if you are pointing it directly down at the road, i.e. vertically down, the distance between you and the road is not changing, so it would read zero speed. I guess if you mounted it looking forward at a shallow angle to the ground, you'd get a reading, albeit not your true speed, but it would be fooled if you were in traffic and other cars got in the way of the beam. Than again I might be totally missing the wway this works
Nov 17, 2006. 9:19 AMMz3FRS says:
Were you to actually try this in the application you offer, i'm betting it would be pretty much useless. Anyone know if this model measures the change in frequency of the beam or times several shots to calculate speed?
Nov 14, 2006. 12:10 PMturbonegro says:
why not use a gps ?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:MySoulWanders
