3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Nook of Justice
Step 3Cutting the facade
Cutting the facade
First thing you need to is create the façade.  Cut as many boards as you need to get the correct height.  If you need a partial board to meet the height requirement then you might be able to use the scrap ends of the other boards.
Once you have all of the boards cut, lay them out on a flat surface by butting the long edges against each other.  Using some scraps of leftover wood, lay out some braces to keep all of the boards together.  Be sure to leave the door area alone; don't put any support braces there.  Nail the braces in place.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
63
Author:The Papier Boy(i got something to say)
This is Kris: Maker of stuff. His specialty: Paper mache and laminated paper. His mission: To keep man a caged animal on the Planet of the Apes
