Nor Gate
Published
Introduction: Schematic
When any button is pressed power will flow to the base of the transistor and it will behave like a closed swith and act like a short and turn off the LED
Step 1: Things You Will Need
2x 12k ,o, resistor
1x 731 ,o, resistor
1x npn transistor
Output(LED)
2x push buttons (or some input like arduino)
Jumper cables
9v battery and holder
Breadboard (or pcb)
Step 2:
Make a simple led circuit. The LED represents an output
Step 3:
Add a transistor an connect Collector to + and Emitter to ground as shown
Step 4:
Add buttons and connect them from the + terminal to the Base of the transistor with a 12k resistor for each button.
Step 5:
Subscribe to my youtube channel:
https://m.youtube.com/channel/UCuSLnXvUfYNq1yX1MefwJ_g
Step 6:
And now your done if you press button A the led will turn off if you press button b it will also turn of and both also off and none on
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
