Not Too Hard Box Puzzle
2,034
50
Published
Introduction: Not Too Hard Box Puzzle
This is called the Not Too Hard Box puzzle because it is neither too hard to solve nor too hard to make. I made one on a weekend morning.
It consists of six pieces, all of which are different, that must be assembled so that they fit together as the six sides of a box. Each edge of each piece has either a slot or a tab. You will notice that there are only six possible different arrangements of slots and tabs around the perimeter of a square. So only six distinct pieces are possible; the six pieces of the puzzle represent the entire set. An interesting thing about the puzzle is that it requires six pieces, and the rules for making pieces yield exactly the number required. I think that this is characteristic of a certain set of puzzles.
Piece #1 has no slots and four tabs. Piece #2 has no tabs and four slots. Piece #3 has one slot and three tabs. Piece #4 has one tab and three slots. Piece #5 has two slots adjacent to each other and two tabs adjacent to each other. Piece #6 has two slots opposite each other and two tabs opposite each other.
Step 1: Materials
About four feet of ½” square wooden dowels. These are available at hobby shops, art supply stores, craft stores, and even hardware stores. Make sure that they are actually square. The puzzle requires a measure precision to work well.
I chose to make my puzzle out of square dowels because they are readily available and glue together nicely. I used basswood because it is not too hard and easy to work.
Some kind of saw to cut the wood into the lengths required.
Some kind of suitable glue. I used 3M wood glue.
Clamps and/or tape to hold the pieces together as the glue sets.
Step 2: Cutting the Component Parts
Cut the component parts.
There 24 parts 1/2” long (cubes, in other words), 12 parts 1” long, and 12 parts 1-1/2” long.
Make a careful pattern for the arrangement of parts that make up each puzzle piece. I drew mine with a CAD program to make sure that it was accurate. Notice that I have outlined each component part in a bold line to show where each one must go.
Step 3: Making the Six Puzzle Pieces
Assemble and glue the parts for each puzzle piece. I used pieces of dowel as spacers to make sure that the slots were the right width to receive the tabs.
Step 4: Completing the Puzzle and Final Assembly
Sand each of the pieces to remove unevenness.
Put the puzzle together. Sand the assembled puzzle to smooth everything off.
I have left my puzzle unfinished, because a layer of varnish could make the pieces slide together less smoothly. But you can finish yours in any way you wish, or color it in any pattern you wish. You could also fill in the holes in the center of each face to make a more solid box to keep something in. Or you could laser cut the pieces out of flat material, so long as there is enough overlap at the corners to keep it from falling apart. If you have a 3D printer….
You are free to realize the idea of the puzzle, having these six pieces that fit together in a six-sided way, in whatever way you can imagine.
Beyond providing a photo of the completed puzzle, I am not giving a solution in this Instructable, because the puzzle is Not Too Hard.
Puzzles Challenge
Runner Up in the
Puzzles Challenge
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
