Not So Primitive, Customizable, Wood Bow!
236
6
Posted
Introduction: Not So Primitive, Customizable, Wood Bow!
Start with a piece of wood, according to its owner. Use the chart on how to start.
Step 1:
After you got the measurements, cut the wood and leave a little bit of depth for later.
Step 2: Shaving
Measure the pre-bow and divide it in half. Mark the half point and two inches on either side to give a four inch handle. Start tapering the board, going away from the handles and sand liberally. When it's reached preferred size, check the flexibility on your knee.
Step 3: Tie
With a hack or bandsaw, cut two small nocks on the edges as a square triangle, the 90* pointing down. (couldn't find degree sign) Then using your leg, pull the wood into shape and tie it. My most recommended string would be kite line or synthetic sinew.
Step 4: The Kaboomer.
To make an arrow, Cut a thin dowel to size and add a nock on both sides. (one larger than the other) Find or buy feathers and peel away one side so you have a half of a feather. Use three half feathers per arrow. Using a tiny bit of hot glue (just enough to make it stick) glue the feathers on, two parallel from the nock, one aligning. Make sure the feathers are about a half inch away from the smaller nock.Then with sewing thread,thread string through the feathers flumps and pull taught to keep the feather bits on. Then on the other aide, get a thin bone or strong rock and put in in the larger nock. Then using thread or yarn, tie it in using diagonal type wrapping.
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    6 Comments
    Hello, and welcome to the Instructables community!
    It's great that you've decided to tell the world about something you've made by publishing an Instructable. We just wanted to let you know that your project still needs a little more work if you want it to be well received on Instructables.
    Projects that don't include certain basic elements tend not to get the attention that they deserve, and so we'd love for you to check out the list below of what makes a successful Instructable.
    Successful projects on Instructables include:
    - clearly written details of a finished project with instructions
    - proper spelling and grammar
    - pictures of the finished project that you took yourself
    I'll give you another opportunity to make any final changes to your project before we publish it. Once you're all set to go, please republish your project and send me a quick comment letting me know that you've made some changes. I'll give it a quick final check to make sure you're on the right path, and then remove this note.
    Thanks for your submission and we hope to see your project published soon!
    Hi,
    Can you please post a photo of your project? The title says it is a bowl, but I don't see any pictures of a bowl. Please let me know when you have done so so we can post your Instructable properly.
    Best,
    Nicole
    Community Support Manager
    I'm sorry. the title says Bow. As in archery. I'll post a picture in the morning when I have access to the supplies. I've made one, but it died. So I have to make a new one, so I'll photo ir
    Great! Sorry about that. I thought the ! was a l. Let me know when you've posted the photo :)
    (I should have put it together when I didn't see a bowl mentioned anywhere!)
    Please make sure to post your own photos of your finished product.
