This was largely inspired by the electronic detonators on this site, especially tetranitrate's
http://www.instructables.com/id/EH6Q99985NEPA8L6YC/?ALLSTEPS
But I decided I didn't like the bulky power supply and multitude of plugs and jacks. So I changed it.
WARNING! this project uses Relatively high voltages and a decent ammount of current to boot.
DO NOT Hold the aligator clips in your hand when the plug on the end of the cord is inserted into the detonator!
DO NOT allow the Capacitor to discharge accross your Heart(it didn't kill me, but it was not a pleasant experience)
ALWAYS Discharge the capacitor with a screwdriver or a nail before working with it, even if you know it is not charged.
ALWAYS discharge the capacitor AGAIN after detonating something. the wires used explode(yes, I do mean explode) before all the current can be discharged and it will still pack a nasty punch.
Lastly, use common sense and don't do anything too idiotic(I know how hard this is going to be for a lot of you, but do try)
Remove these ads by
Signing UpStep 1Gather Materials
1 PCB from a disposable Camera that has a flash feature(you need to rip the camera apart)(these can be bought or you can just go into any place that develops film and ask for a few(walmart gave me a shopping bag full) I used a Kodak Hi-definition, but any one would work)
1 Capacitor from the camera(needs to be cut off of the camera PCB)
1 Altoids sours tin(I'm sure that a normal one would work too, but I like the roundness of the sours tins)
1 AA Alkaline battery(included with camera)
1 Push Button Normally Open switches
1 Mini toggle switch
1 1/8" Mono Jack
1 1/8" Mono Plug
~8" 24 Guage Solid Core Hookup Wire
As long as you like of 18 Guage Double stranded hookup wire(I fully reccomend the hardware store, they tend to be cheaper than the shack)
Aligator clips
Jewelry bead wire
Tools needed are as follows:
1 Drill
Drillbits of appropriate size for your components
Gaffer's Tape or Electrical tape(even ducttape would work)
Circular files of appropiate diameter for your holes
Soldering Iron
Solder
Fancysaukrel
Go ahead and post your own version, just make sure its significantly different (i.e. a different way of charging the cap or a different way of delivering the current) otherwise it's basically just a re-casing, and instructables already has plenty of detonators floating about.
Good luck, and remember that limbs are meant to stay on your body.
-A
cheers,
mspark400
