Introduction: Notice Board
Hello!
In this instructable I want to show you how to make this notice board.
It's created in a way that you can choose how big it has to be!
Step 1: Tools and Materials
What tools do you need:
- a cutter
- a saw
- a screwdriver
- measering tools
What materials do you need:
- Cork (thickness 4mm)
- 4 screws or 2 hangers
- Wood (18-25mm, you can choose the lenghts)
- 4 3D printed hook profiles (see stl-file)
Step 2: Print
3D print the hook profiles
Step 3: Saw the Wood
Start bij sawing the wood in the desired lenght.
You don't need to saw the wood in miter.
Step 4: Cut the Cork
The easiest way to do this is when you put the wood and hook profiles together and cut the cork around the framework. It is recommended to cut the edges a centimeter smaller afterwards.
Step 5: Put the Hook Profiles Over the Cork
There is a provided space in the hook profile where you can slide the cork in.
Step 6: Stick the Wooden Bars in the Hook Profiles
There is a provided space in the hook profile where you can stick the wood.
The cork will clamp against the wood. In this way the 3 materials are secured to each other.
Step 7: Screw
Now you can screw the notice board to the wall. Put each screw close to a corner and it's almost certain that you will screw in the provided hole of the hook profile.
When you don't want to screw in the cork, you can also use a little glue to glue the cork, wood and profile against each other and use 2 hangers to hang the board.
Step 8:
3D Printing Contest 2016
