Gracias a Gaffer ha creado un completo tutorial para tunear nuestro Nunchuck añadiéndole luz bajo el stick. Con un simple diodo LED y sin necesidad de demasiada habilidad se puede tener un acabado realmente psicodélico y futurista. Si elegimos un LED azul, hará juego con la consola.
Step 1: Materiales
Materiales:
1 Nunchuck
1 Destornillador cabeza estrella pequeño de cuerpo muy alargado.
1 Alicate de punta plana
1 LED de tu color favorito
1 Soldador y estaño
Dekubaba94 says: Apr 20, 2011. 1:36 PM
The screw is an odd shape. can anyone tell me where to find a screwdriver for it? (hint: look at your own nunchuk)
monty324 in reply to Dekubaba94Dec 3, 2012. 10:12 AM
it is called a try-wing, you can buy a special one, made for dismantling the wii console that fits perfectly
jwystup says: Sep 6, 2010. 8:47 AM
aww man why did it all show up on this step? oh well, hopefully it will help people.
jwystup says: Sep 6, 2010. 8:46 AM
Step 6: Connect the Wiimote and Nunchuck to turn it on. You'll have something like this:
jwystup says: Sep 6, 2010. 8:45 AM
Step 5:
Place the stick, close the housing again Nunchuck and use the screwdriver to properly position the screws.
Step 4: Place the LED on the printed circuit board as shown in the image. Solder the LED pins to the two "test points" (one blade for each point). Make sure the LED pins do not play any contact and head about everything possib led to the white box of the stick.
jwystup says: Sep 6, 2010. 8:44 AM
Step 3: Use the flat nose pliers to bend the pins of the LED L-shaped as in Fig.
Step 2:
Locate the two "test points"
jwystup says: Sep 6, 2010. 8:43 AM
Step 1:
Use the screwdriver to remove the screws from the casing of the Nunchuck and separate the two sides.
I'm translating this through Google translator because I'd like to make this sometime. It looks pretty easy and awesome. Hopefully it will benefit others.
Thanks to Gaffer has created a complete tutorial for adding tune our light under the Nunchuck stick. With a simple LED and without much skill can be finished really psychedelic and futuristic. If you choose a blue LED, will play with the console.
Materials:
1 Nunchuck
A small star head screwdriver elongated body.
A flat nose pliers
1 LED in your favorite color
A welder and tin
chopstx says: Oct 22, 2009. 1:10 PM
Whaaaaaaaa???????????
lemonie in reply to chopstxOct 22, 2009. 1:16 PM
I believe they put a blue LED into it.
L
chopstx in reply to lemonieOct 22, 2009. 1:58 PM
Yeah, but why in spanish(or some thing)?
lemonie in reply to chopstxOct 22, 2009. 2:00 PM
I guess they live in a Spanish / Portuguese speaking country.
L
chopstx in reply to lemonieOct 22, 2009. 2:01 PM
Yeah.............
I'm english if you can't tell.^der
lemonie in reply to chopstxOct 22, 2009. 2:10 PM
Just look at the pictures then.
L
chopstx in reply to lemonieOct 22, 2009. 2:31 PM
No, I don't have a wii..........
I was just looking.
AlfredoSG in reply to chopstxJan 22, 2010. 7:04 PM
 Pointless conversation. Ended
chopstx in reply to AlfredoSGJan 23, 2010. 8:22 AM
Okay..................
What gives you the right to say that?
AlfredoSG in reply to chopstxJan 23, 2010. 9:16 PM
 I no speeki the engli
chopstx in reply to AlfredoSGJan 24, 2010. 7:34 AM
Really? Then what is up there? ^
AlfredoSG in reply to chopstxJan 24, 2010. 9:02 AM
 Noo...no
chopstx in reply to AlfredoSGJan 24, 2010. 11:51 AM
What?
AlfredoSG in reply to chopstxJan 24, 2010. 5:37 PM
 yes please
chopstx in reply to AlfredoSGJan 24, 2010. 6:07 PM
Here you go. *hands AlfredoSG a cup of tea.*
AlfredoSG in reply to chopstxJan 25, 2010. 5:45 PM
 Your a scholar and a gentleman.
chopstx in reply to AlfredoSGJan 26, 2010. 1:44 PM
Yep.
O_Kodama in reply to chopstxJan 28, 2010. 12:22 PM
LOL'D!
chopstx in reply to O_KodamaJan 28, 2010. 1:32 PM
pancho del rancho says: Oct 22, 2009. 6:59 PM
esta chido pero por la proxima vez se puedes en english porque onos no sabien espanol con translator o algo
brunoip says: Oct 22, 2009. 4:02 PM
Lo tendrias que haber hehco en ingrles ¬¬
Saludos
grenho says: Oct 22, 2009. 3:03 PM
Hey, nice project!
I'm from Portugal and I would like to enlighten you that this instructable is in Spanish. Nothing you can't understand with the help of an translator
Keep it up ;)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
